Originally Posted by
cavekidd
Hey fam.
I want to make a thread for myself and every B5 owner looking to have a strong, long lasting, fun car.
I want everyone to contribute on the initial and most essential upgrades you've gotta do as soon as you purchase your new B5 A4.
I have a 98 1.8t quattro.
What are the best things to upgrade to maintain and strengthen the engine?
Coil packs?
Clean the engine internally? Replace head gasket, clean pistons etc?
Better fuel injectors?
Sway bars?
Better Turbo?
stainless steel braided break lines?
hoses?
valves?
coolant?
coolers?
ETCCCCC!!
List them all! .. according to importance & benefit of course :D
Thanks yall!
If it were me, and looking only at maintenance issues before upgrades, I would suggest the following;
1. Replace the timing belt, water pump, thermostat and various idlers and rollers unless you KNOW that this has been done recently.
2. Change the engine oil & filter.
3. Check coolant level and look for leaks.
4. Inspect the front axles for torn boots and?or worn CV's.
5. Replace the trans fluid (No Flush).
6. Replace the diff oil.
7. Check brake fluid level and condition, replace if necessary.
8. Check center drive shaft support. Replace if necessary.
9. Buy a real VCDS dongle.
As far as upgrades are concerned, this will vary depending on the age of the engine and whether a person has manual or tip transmission. I did the following on my '01 tip
1. Borla exhaust.
2. Giac Tune
3. Bilstein shocks and H&R lowering springs
4. S4 rear sway bar
5. S4 Replica wheels
6. 710N valve
Currently at about 215000 miles and counting.
Thanks
