Results 1 to 9 of 9
    Jun 10 2011
    Tampa, FL
    Battery Help..Thanks in advance!
    So my battery dead yesterday while doing errands. Roadside Assistance came and jumped me no problem. Drove around a bit to try to charge it up but I have been home bound with small kids and only have so many cold starts left on this battery it seems.
    Can you guys clear something up for me? I read
    • You need to take it to the dealer or have some sort of Aux battery to keep the car "alive" while you swap out batteries or the computer and radio will need a reset. (Also have some mods, lights, gauge sweep etc that people report will get wiped)
    • Also saw reports of no such issue.
    Before I pick up a battery and swap it out or spend the $$$ at the dealer.....what is the deal with changing the battery?
    I appreciate your help!
    Mar 21 2015
    Some change the battery and that's it. Others claim you're supposed to code the battery in vcsd. There are threads on this.
    Oct 10 2012
    Zionsville and Saint John IN
    Just change the battery out. Nothing will get reset other than the time and date maybe. It is recommended to change a number through vagcom so it is recognized as a new battery. If you don't do this, it is not the end of the world lol. I bought mine from the dealer.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Senior Member Two Rings Vinhouw's Avatar
    Jan 14 2014
    my two feet
    Tampa, FL
    You need a compatible battery for optimal and adequate charge from your vehicle... You could use any batteries, but the ones that are not programmed into the ecu will be affected life wise.
    Apr 19 2014
    Long Island
    Quote Originally Posted by Vinhouw View Post
    How does programming affect the life of the battery?
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Quote Originally Posted by homelessNY_LI View Post
    This has been discussed in detail in the battery swap thread look through it.
    Apr 19 2014
    Long Island
    Quote Originally Posted by bluetori View Post
    Thanks for another worthless reply
    Jun 10 2011
    Tampa, FL
    Thanks guys, changed it out and it fired right up with everything except time and date intact. Will have to look into how to program for the new battery.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Check the batteries warranty first. I had mine replaced by dealer free of charge
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
