Results 1 to 28 of 28
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    How high do your STs go?
    So it's winter mode time, and I know a lot of you don't go all the way up, but I'm sure there's a couple who do. Could you guys tell me how high your fender to ground is with your STs all the way up? Especially the rears.
    My fronts have a bit of a wheel gap, my rears almost tuck some tire. Seems off but I think I have the rears adjusted as high as possible. I just want to be sure I'm getting as much clearance as possible.
    Does anyone have the measurement on the rear adjuster that's maxed out? Maybe that's all I need.
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Be sure to spray or coat those threads with some sort of anti seize if you get a lot of salt on your roads.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by Solarsuplex View Post
    I use marine grease hahah. Buffalo winters are probably some of the worst on cars. We use so so much salt
    Aug 20 2011
    Seattle Wa
    Word, If the rear doesn't go high enough you could always just put the stock rear springs in
    -James
    Dec 08 2013
    Buffalo, NY
    It was such a pain to get them switched out the first time haha. It's not like they're too low for winter, I just find it funny the front and rear aren't even at each's "highest" setting
    Aug 20 2011
    Seattle Wa
    I feel the pain swapping. Just put somewhat stock springs back in the rear. ST's are known for not matching heights. Though most people are referring to their minimum height.
    -James
    Dec 08 2013
    Buffalo, NY
    Hm I'm wondering if I'm getting spring sag in the rear.
    Anyone have their rear STs at max or no?
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by 2pointOh View Post
    Mine are pretty close to max in the rear and I don't think I would want to go lower. It almost tucks the tire at the current height. I've even considered getting a set of Hyperco springs with a higher spring rate, just so I could go HIGHER in the rear.
    -Adam
    Dec 08 2013
    Buffalo, NY
    Hahah yeah seriously. For summer it's fine but winter I don't think I can get more height out of it. I just don't like the rake look
    Mar 24 2013
    Oakdale, CT
    I haven't had any issues in the winter with mine. The only time I've gotten the car stuck with the Blizzaks was when the snow was up to the hood. Too much got packed under the car and I got hung up on it. I did make it a decent ways before this happened though.
    -Adam
    Jun 17 2013
    jersey city nj
    Damn you guys get alot of snow up there.
    Ive got my ST's all the way up in the back and have my fronts level out to the back. I ed these when I was on stock 17's. I have not ed them even after the 19's. Ive bought a complete set of 18's with blizzaks WS80's off CL from a S5 guy. I dont plan on the coil overs either on these. Probably these after Xmas
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by vce1232000 View Post
    Can you measure your rear FTG for me? I just want to be sure they're at the highest.
    Thats amazing hahah. My only concern is that I lost my belly pan last winter, and that "cost effective" rock auto one is flimsy plastic from what I've read. So trying to maximize height haha.
    Jun 17 2013
    jersey city nj
    Measure it as soon as it stops raining. Forecasts for 2 days on steady rain thou
    My belly pan scraped off long ago in the ty NJ pothole roads. I never bothered ing it
    Established Member Two Rings PenTico's Avatar
    Aug 18 2011
    B7 A4 AVANT S-LINE 6MT
    Hamilton/Canada
    Adjusted my ST's today (raised the rear) and had the rears at 27" ftg. thats as high as it would go for me. wheels are 18" also using the ST springs. currently sitting at 26" ftg as i don't want to damage the rear fenders during the winter after Audi painted them under the rust perf warranty.
    AVANT 6MT PHANTOM BLACK/RECAROS/APIKOL DIFF MOUNT/ O34 TRANS+MOTOR MOUNTS/BREMBO 18Z FRONTS-S4 REARS w HAWK HPS PADS/H&R 12.5M SPACERS/ST COILOVERS
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by PenTico View Post
    Thanks! I'll measure mine tomorrow and compare. 26" would be fine for me. For some reason I doubt I can touch 27"
    Also, did you have a hole through the panel? I have rear quarter panel rust on the passenger side
    Aug 18 2011
    Hamilton/Canada
    I didn't have any rust "breaking through" the paint ,just rust "bubbles". They where 4-5 inches in length at the bottom of the fender. My front fenders were not covered as they cited chips/scratches as the cause of the perforation. The whole process was a headache.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Not the best pic, but these are my STs with them set pretty close to the highest front and rear with 17x8 et35 and 235/45/17s
    Dec 08 2013
    Buffalo, NY
    Huh, you're lucky. I have the same thing but no perforation no luck on the warranty.
    Quote Originally Posted by chris@fifteen52 View Post
    Ah yeah okay somethings up with mine. Not nearly that height in the rear. Do you know, even an estimate, on how high your rear adjuster is set? I think mine is only about an inch, maybe I just need to crank it higher. It felt like I was at the end of the threads though.
    Established Member Two Rings coulditb7's Avatar
    Nov 15 2014
    Wisconsin
    I actually just raise my car back up the other day and at the time, wondered that same thought. I have STs with hyperco's in the rear. I went max height in the rear with my ST Springs and I was sitting at approx 26''. So that's what u went with on all four corners
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    My max on the rears is just under 26" ftg. That being said, in the summer I put the rears down all the way and it seems to barely make a difference (~25" ftg at the lowest). They really don't move very much no matter how far I adjust them.
    The fronts I can raise/lower dramatically though
    Nov 15 2014
    Wisconsin
    Sounds like you need some hyperco's. When I swapped spring to those I left my rears where they were just for giggles. 24.25ftg. About as low as I could with my all-seasons
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by coulditb7 View Post
    What's your max rear with the hyperco's?
    Dec 08 2013
    Buffalo, NY
    So measured my ftg, I'm at 26.3" in front and a full inch lower in back.. I'm gonna have to see if there's any more room to move the adjuster. Once it's maxed out will it just stop turning? I don't wanna break it
    Dec 08 2013
    Buffalo, NY
    Another update, I checked my rear adjusters and I'm pretty sure they're all the way extended. None of the black threaded base sticks out from the collar. Yet they're an inch lower than the front. Think st will send me new springs?
    Oct 04 2012
    Everywhere
    The fender to ground will be lower in the rear because if you look the rear fender is much lower than the front.
    Dec 08 2013
    Buffalo, NY
    Ah makes sense. But like coulditb7 said his FTG in the rear is about 26" while mine is just over 25". Hm. Maybe I should just lower the fronts to match and hope there's no issue with the snow.
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    TL;DR... Did you guys compare wheel/tire setups? That would affect FTG heights. Just a thought
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by 617 Bones View Post
    I'm actually using a 55 series 17" snow tire, so if anything mine should be higher than normal hahah
