    Aug 31 2015
    MMI freezing when connecting to phone
    Has anyone had issues with their MMI (3G) freezing when their phone connects? I have a samsung galaxy s6 and when the phone connects my mmi will freeze for about 15 seconds or so. This includes the radio, backup cam, gps, etc. My old galaxy s3 works though.
    Is this an issue that has been addressed in an update?
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Is the address book different in the S6? Might be trying to update and sort through the numbers? Did you clear out all the other phones from the MMI memory?
    Aug 31 2015
    Quote Originally Posted by JamesRS5 View Post
    The android version is newer so it might be but I have unchecked the "send contacts and call logs" option and it still freezes. I cleared everything out of the bluetooth memory on both the phone and mmi. I even tried unpairing and repairing a few times.
    The freezing has an oddly consistent pattern:
    Freeze for 20 seconds -> Unfreeze for 5 seconds -> Freeze for 5 seconds -> Unfreeze.
    Feb 27 2014
    Dubai
    Is it exactly the same if you let it update the contacts?
    My MMI will freeze for a approximately 5 seconds as it updates the contact list etc, that's on my works shitty Blackberry Q10.
    Aug 31 2015
    It does the same exact thing whether I update contacts or not. And it is much longer than 5 seconds. My backup camera is unusable most of the time since I will be out of the spot and 2 lights down by the time the MMI unfreezes...
