Results 1 to 3 of 3
    Nov 24 2015
    Clifton, NJ
    Porsche Twists 18x10
    Hi guys, I found 5x130 18x8 front and 18x10 rear Porsche Twists for $650 and I was wondering if I could use them without adapters for a week or two? Im not even sure if they will fit without adapters but any advice would be great thanks! When I get my adapters should I get 20mm for the front and 30mm for the back?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    There is zero chance of fitting without adapters.
    Since Porsche wheels are usually somewhere around et50, you'd want 20mm adapters to get to et30. 30's would probably rub, but then again 10 inch wide wheel might not fit without 30mm adapters. You may be pulling fenders
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Nov 24 2015
    Clifton, NJ
    Thanks I think ill just stick with 17x7.5s until I find something better :/
