Results 1 to 9 of 9
    Feb 03 2010
    Pittston, pa
    front plate delete
    before and after pics. just sanded screw holes filled them a bit with a little silicon just so not to have a dimple.
    Bought some carbon fiber vinyl.. cut the strips and think its a good look.. could have just got.plain black vinyl.
    Hope it helps others out their with same situation.. Was a very easy fix.
    first time posting a pic.. hope it works..
    Veteran Member Three Rings Hatchman's Avatar
    Jan 14 2014
    B8 S5, G35, C-Max
    Huntersville, NC
    Quote Originally Posted by NEPA A8 View Post
    Not seeing the pics here, but could be my computer.
    2010 S5
    Meteor Grey, Tuscan Brown, Tip, Prestige, Nav, B&O
    Borla Exhaust / AG M510 / H&R Springs / 034 Motorsports Motor,Transmission Mounts / Akebono / CR-15 / RS5 grill / E-Codes
    HEX-USB+CAN
    Feb 03 2010
    Pittston, pa
    yea I don't think i link pics correctly.. just to to my photos.. only ones their..
    Veteran Member Three Rings szaer's Avatar
    Mar 14 2013
    Greater Toronto Area
    Pics showing up now for me, not in the quote tho. Do you have a pic a little further away? I did mine in satin black
    2014 Lava Grey S5
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Good idea for covering holes without doing bodywork and paint. Also, nice use of the carbon fiber vinyl as an accent.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Established Member Two Rings Zonsolo's Avatar
    Sep 14 2015
    OH
    Looks great to me. Nice job.
    ►Zonsolo◄
    2011 S5 6MT AWE Touring KW HAS Custom Hypersilver Niche Targas 20x10.5 Hankook 285s
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    I did the exact same thing as the OP, except I used matte black vinyl. I did not fill the holes figuring the vinyl would bridge over them, which it mostly does, but at certain light angles, the holes are visible, so good call on filling them. I may peel mine off, fill the holes and redo it as an afternoon project.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Senior Member Three Rings jrabakker's Avatar
    Feb 27 2014
    for matte black, you can just get this: http://www.amazon.com/gp/product/B00...ilpage_o04_s01
    exact width of the slots of an S5 grill, no need to cut or anything.
    2014 S5 | Premium Plus | Estoril Blue | Black Napa Interior | Sports Diff | Adaptive Damping | Side Assist | Supercharged badges | HR OE springs | 10/15 mm spacers fwd/aft | APR stage 2 | AG M510 - 20x10 - 275/30/20 |
    1st Car | 1988 80 B4 | Blue
    2nd Car | 1998 A3 1.8T | Sport Green
    Jan 07 2011
    2013 C300 4Matic
    great job, I like the faux cf accent on the grille
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
