Results 1 to 40 of 46
    Jan 24 2014
    United States
    How can I tell if a b8 s4 is tuned?
    I just bought a 2011 s4.
    How can I tell if the car is tuned? It feels way faster than it should but I've never driven another one
    Jul 16 2012
    2010 Audi S4
    Charlotte, NC
    If it goes over 155mph then it has been tuned. Haha jk, do not try that!
    Jan 24 2014
    United States
    Lol I has an awe exhaust and intake of that helps
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Quote Originally Posted by LaCross View Post
    LOLL... probably just feels faster bc of the louder exhaust
    2021 SQ5
    2008 A4 Avant 6 speed
    Senior Member Two Rings Nightkiller6's Avatar
    May 30 2015
    San Diego, California
    Where did u get your car from? They might be able to tell you whether it be a dealer or private party.
    B8.5 Ice Silver A4
    Mod List- USP Motorsports Full Interior Lighting Kit | USP Motorsports RFB Led Reverse Lights | Hoen Xenonmatch Fog Lights | iJDMtoy Led Front Turn Signals | USP Motorsports Honeycomb Grille | Hartmann HTT-256 MA-M 19x8.5 ET 38 | Michelin Pilot Supersport 255/35/19 |
    Nightkiller6 is my Xbox gamer tag I made when I was 8.
    Jan 24 2014
    United States
    It was a dealer. And I'm coming from a fbo 135i
    Apr 11 2012
    Audi underrates it, but you might be tuned also.
    Jan 24 2014
    United States
    Yea but how can I tell ?
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Boost gauge
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Established Member Two Rings Sigmon20's Avatar
    Aug 01 2015
    NOVA
    I know for an APR tune if you go to launch the car the revs will be over 3200 rpm, 3200 is what a stock S4 will settle at before launching. Tuned cars usually have a higher rev
    Edit: for a B8.5 at least
    2014 Audi S4 Black P+ | S Tronic | Sports Diff | B & O | Carbon Atlas | 50% tint front 35% tint rear | H&R Sport Springs | AWE Touring 90 w/ Stock DP| StopTech Sport Drilled and Slotted Rotors | Akebono Pads | Hoen xenonmatch fogs | Grafixpressions
    May 30 2015
    You could probably call the dealer you bought it from whenever they open and see what they know. If they dont know, find an Audi dealer and go test drive another S4.
    B8.5 Ice Silver A4
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    Launch RPM if auto trans, tuned will be higher. And if your 6MT, just see if it will rev past red line with out cutting out, tuned will push right past 6500 and will still be pulling hard. When the engine is stock, it kinda stops pulling after 5500 RPM.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    well the easiest way to know would be the raised redline in the tuned version vs stock. The stock in Manual mode will usually shift way before 6500rpm, the tuned will probably go all the way upto 7000-7200rpm. Also if the previous owner disabled automatic upshift in manual mode, like i did, you will bounce off the rev limiter like in a true manual until you trigger an upshift via the paddle.
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Jan 24 2014
    United States
    My car is manual lol
    Jun 20 2015
    NC
    Measure the pulley, that will at least tell if stage 2 or not
    Jan 24 2014
    United States
    Pulley is stock. Also the supercharger is silent
    Jun 20 2015
    NC
    Supercharger can be loud even Stock, just depends on which intake. FWIW the APR pulley is identical to OEM just smaller (same texture, color, etc.)
    Run it to Audi, they will tell you. Half the threads on this forum are about trying to hide the tunes from Audi lol
    Jul 24 2015
    LOL whoops, I jumped the gun there, but either way I believe the rev limiter is raised for both to about 7200 instead of the stock 6500. Maybe test drive a stock car at the dealership. Or if you have Carista or similar Bluetooth OBD 2 dongle, you can use an app like Torque Pro to check your boost, if stock you should see a boost leak around 5500rpm which will cause the car to stop pulling like @u2nelson said.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Log boost, log a/f ratio, try to go over 155, race a stock S4 of the same model, or go in for warranty work and see if your car flags a TD1.
    Recommend 1 or 2.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Aug 02 2012
    Boston
    Email major tuners with you vin and ask if they have your car on file.
    2017 S8
    Sep 27 2008
    Phoenix
    Do 1/4 mile runs and see what sort of times you hit.
    Established Member Two Rings ruamit03's Avatar
    Jun 08 2015
    Central NJ
    You can take your vin and call APR, GiAC and the others. I know APR can't tell you what stage, but if you are running their file then they have the vin in file.
    Veteran Member Four Rings Saud's Avatar
    Mar 25 2012
    14' RS5
    VA/DC
    if it flys
    HRE and Armytrix for sale + sig parts
    Ordered 8/2011 S4 DSG SD 2012 White/White -
    Armytrix F1 - VMR-710 19"- HRE P44SC 20" -
    RS4: cluster, B8.5 piano black surrounding, -
    Carbon Fiber / DTM lip + Osir fog cover + Rieger diffusor
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    Jan 24 2014
    United States
    Me thinks the app idea will work. I still have my old cable somewhere
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    I thought the same thing on my car. turned out to be stock. so few of these cars have actually had software done on them and then sold--you get a warped perspective here at an enthusiast forum. seems like every S4 out there is tuned. probably really like 5% of them are.
    stock these cars are pretty fast--R&T got a 4.5 seconds to 60MPH -almost as fast as the V8 R8. I later did stage 1 EPL tune on mine with some E85 added, and the car is now more responsive and pulls harder for sure, especially at the higher rpms. But it is not "way faster" than stock because stock was already fast..
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    LOL... explain to me how do you know if feels WAY faster if you've never driven another one?
    What other mods did it come with? If none then I'm willing to bet it's not tuned.
    These cars are quick in stock form...
    Where are you located? Meet up with a friendly AZ member with a tuned S4 and have him/her test drive you car... should be able to tell...
    Jan 24 2014
    United States
    Because it feels way faster than 330hp... Mind you my 135i was putting down 400whp. Has an awe exhaust and intake pipe
    Apr 04 2012
    MSP
    Stock they are about 360 (under rated at 330 as Audi typically does). If you don't have other mods I'd be willing to bet you are not tuned.
    Apr 05 2009
    SF BayArea
    Quote Originally Posted by MrFunk View Post
    This. stock these cars make close to 300WHP. supercharged cars always seem faster to me than they should as well in general, I think its the power curve and instant response that does it.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Rev in neutral to test if rev could climb over 4K RPM,if it does, then it is probably tuned.
    The OEM 6MT has limitation of 4K Rev in neutral.
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    May 11 2015
    Georgia
    When you floor it, see if it goes vrrooooooMMMMMMM!!!!! If it doesn't you're probably not tuned.
    2013 S4 Monsoon Grey 6mt
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    see if you can hit the brake and gas at same time. srsly.
    from APR:
    "APR's Left Foot Braking feature allows more control over the vehicle’s throttle. The factory equipped vehicle's throttle input is disabled while pressing the accelerator and brake at the same time. Left Foot Braking, a common motorsport driving technique, allows the driver complete control over the vehicle’s throttle and braking system, which may give the vehicle the edge it needs at the track."
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Jan 24 2014
    United States
    After doing a 1-2-3 pull I have determined that the car is not tuned
    Jul 21 2004
    South Florida
    How?
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    So, tune it! :)
    Jan 24 2014
    United States
    Quote Originally Posted by Sean@APR View Post
    So, tune it! :)
    Got any deals? :)
    And the car was slower than I thought. I didn't really have time to do a healthy pull before but first gear was still impressive. These things pull stock
    Apr 04 2012
    MSP
    What's changed your mind?
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    ^OP finally came to his senses... he was so sure it was faster than stock despite having never driven another one before or way to quantify (all subjective butt dyno and anecdotal with his fbo 135i)
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Jan 24 2014
    United States
    Quote Originally Posted by vwblackb5 View Post
    If I was sure I wouldn't have made a thread :) let's use the noggin
