Results 1 to 4 of 4
    Jun 26 2012
    United States
    Boost leak - pcv system?
    I've been fighting a random misfire and lean idle condition. I decided to pressure test and the only leak was coming from the pcv (pancake) valve. Is this normal? If not, what should I consider inspecting/replacing?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    It shouldnt if you have the oil cap off, but sometimes you can feel a little coming out.
    If it is a lot, prob the check valve.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 24 2014
    Newport Beach, CA
    How did you test the PCV system? I thought it had to be capped off at the y-pipe when doing a boost leak test?
    2024 M3 Comp xDrive
    Jun 26 2012
    United States
    Quote Originally Posted by christianb5s4 View Post
    You remove the pancake valve from the Y-pipe and cap off the Y-pipe connection.
