Results 1 to 24 of 24
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    RNS-E GPS Adapter
    As stated, I need the RSNE GPS cable/adapter. I'm doing the retrofit, but the unit doesn't have the GPS cable.
    Anyone have anything?
    _____________________________________
    B7 2.0T 6MT Avant. JHM test pipe, APR Carbonio Intake, 034 TIP, S3 injectors, APR HPFP, Stasis Cat-back, Eurojet billet VC, 42DD catch can, OEM black optic RS4 grill.
    More to come.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Have you contacted Enfig?
    Jul 04 2015
    Toronto Ontario
    Nope. No idea what that is... Hoping to get one from someone here, if there is a spare.
    More to come.
    Nov 15 2011
    Montreal | I sell in USD
    RNS-E GPS Adapter
    I assume you have an S2
    http://www.ebay.ca/ulk/itm/221178610487
    *****I sell in USD*****
    Senior Member Two Rings tlaudi's Avatar
    Jul 03 2014
    [SOLD] 2008 A4 S-Line Titanium
    What kind of unit do you currently have in your car?
    Jul 04 2015
    Toronto Ontario
    I have a symphony 2+ and have the RNS-E ready to go in. Both are from non-Bose vehicles.
    This is the harness I have. I just need the GPS setup; whether it's the extension to the Avant shark fin, or the magnetic one, it really doesn't matter to me.
    More to come.
    Jul 03 2014
    I just did the swap this week, I have the bose system though and all the harness were the same.
    All I had to do was get the gps antenna on ebay and it was plug and play.. not sure if it's 100% the same for non bose setup.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by tlaudi View Post
    That is very encouraging. Thank you very much for the heads up.
    More to come.
    Mar 05 2014
    phoenix/az/usa
    You can try to contact Enfig as well and tell them what you're doing. They should have the cable for about $20.
    enfigcarstereo.com
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by onedumslack View Post
    enfigcarstereo.com
    More to come.
    Mar 05 2014
    phoenix/az/usa
    If you didn't already realize it, you're going to have to run the cable from the driver side of the trunk up to your head unit unless you get one of the magnet ones and just keep it in the dash.
    Jul 04 2015
    Toronto Ontario
    That is what this entire WTB thread is all about. I'm writing to ask if anyone has one for sale...
    More to come.
    Mar 05 2014
    phoenix/az/usa
    Quote Originally Posted by james12lucy View Post
    More to come.
    :-) yeah. I just wasn't sure you knew the antenna connection was located back there. I picked up my cable a few weeks ago from Enfig and haven't spent the time to put it in yet.
    Nov 15 2011
    RNS-E GPS Adapter
    With an S2+ all you have to do is move the kline wire in your quadlock (Bose also if Bose)
    Then order a female to female 5m fakra extension to connect your oem sharkfin, dont buy a cheap gps antenna it either wont work properly or will stop working properly after a year.
    http://www.ebay.ca/ulk/itm/380213902958
    Jul 03 2014
    I should probably do this conversion later ^. Thx.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by Axis View Post
    Thanks Axis, as always, you're super helpful. Beers are on me when I come to Mtl for hockey.
    More to come.
    Nov 15 2011
    More to come.
    No worries, oem gps connection of your shark fin will be in the driver side C pillar.
    Jan 02 2014
    LaSalle, Quebec, Canada
    More to come.
    I just did the RNS-e swap and bought the 5m Fakra cable extension to go from the RNS-E to the sharfin. Had a gps antenna with the magnet but couldn't get more than 3 satellites. Axis told me about the cable since we are 10 minutes apart and now I have 8 satellites.
    Highly recommend the Fakra extension cable! And Axis did the mod this week end with great results ( as always!)
    Good luck!
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    It was in the passenger side c pillar for me, and I went from non bose s2 to rnse with nav using the fakra extension from enfig.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Nov 15 2011
    Quote Originally Posted by Der Konig View Post
    Weird, maybe its an avant vs sedan thing because Guig'z just did it in hi is 07 Sedan (Edit : just noticed he posted above you) and it was in the driver side.
    I imagine the best way to do this is to remove the rear dome light, rear headliner section and make sure which way its going before removing any additionnal trims.
    Quote Originally Posted by Guig'z View Post
    Good luck!
    My mod was a bit more extensive lol
    Jul 09 2009
    Cleveland OH Area
    A year thing also maybe? Mine is an 06
    Nov 15 2011
    Consider yourself lucky lol, my 06 didnt have a freaking sharkfin, I have the B6 style antenna amplifier in the rear headliner...I had to drill my roof, install sharkfin and then run an extension to the RNS-E
    Jul 09 2009
    Cleveland OH Area
    Wow, drill the roof? You are a brave one my friend.
    Jan 02 2014
    Mine was passenger side Axis! The amplifier and radio antenna goes by the left side!
