Results 1 to 6 of 6
    Account Terminated Four Rings
    Oct 15 2013
    pennzoil ultra platinum 0W-40
    have you tried this? where did you buy it? i can't find it anywhere.
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    just get mobil1 0w40. Cheap @ walmart $26/5quart. Very comparable oils.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Or get shell rotella 5 quarts $19.99 at walmart
    Sent from my C5306 using Tapatalk
    Ivan
    Jan 24 2013
    Chicago
    I find that oil consumption was higher with t6 than with m1 0w40. That's why I made the switch.
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Try liqui moly
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    I've never used Pennzoil Ultra Platinum 0W40 because of the exact reason you posted here....it's difficult to find and probably expensive when you do. The above mentioned suggestions are popular because they're typically readily available. My employer has Castrol Edge Professional 5w40 in bulk but I still use Wally-purchased M1 0w40 because it's a better product @ a lower price.
    ll Audi Sport "Vorsprung Durch Technik"
