Results 1 to 9 of 9
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Learn me on sway bars
    been looking at the 034 rear, I have PSS9s, want to add the sways bars for much more stiffness. Anyone have any suggestions for fronts or any other companies that are good?
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    What do you want to accomplish with new sway bars?
    Old Geezer, formerly known as Stud Muffin
    Mar 14 2013
    Quote Originally Posted by QIKRNU View Post
    well the coilovers do a good enough job to handle, but I want to make the body stick more to the ground, I want to get the 034 rear, which I did, but also want to upgrade the front while I'm at it
    Jun 18 2010
    East of Cincinnati
    Quote Originally Posted by [a]bek. View Post
    Are you looking for more oversteer or more understeer, or are you trying to get the car more neutral?
    What size are the bars you are talking about? Are they adjustable?
    Are you planning on tracking the car?
    Jun 18 2010
    East of Cincinnati
    P. S. We can't "learn" you on anything. We might be able to provide you with information, but you have to learn.
    Established Member Two Rings ArcticAvant's Avatar
    Apr 10 2012
    United States
    Hey,
    If you purchase the 034 rear sway bar along with their end links and put it on the stiffest setting, you will fall in love with your car all over again. One of the best mods I did. Go 034, man. And def get endlinks cuz stock ones look like tooth picks.
    Peace
    Mar 14 2013
    Quote Originally Posted by ArcticAvant View Post
    Hey,
    Peace
    I know, I can't wait for them to come in, I got the sway and end links, I want to find a front now
    I know, lol just wanted to make a funny title
    Yes, when I move from NJ to FL, I will throw it on the track and I purchased the 034 rear with end links and now want to stiffen up the front.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    You should get the rear installed and go from there. I think where others are trying to lead you is the rear pretty much eliminates the under steer. I have it on my car and it makes a heck of a difference If you want the car to be a lot flatter, you can upgrade the front, but then the under steer is more likely to be an issue again. It depends on what you're trying to accomplish. At least, that's how I understand it. Please correct me if I'm wrong.
    You'll love the rear though. Be liberal with the locktite. I had a bolt fall out of my end links and had to go replace it from a local hardware store!
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    I have Hotchkiss RS4 front and rear sways. By far one of the most noticeable mods and something i suggest everyone pick up. Instantly made the car feel more tight.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
