hi. this is not the first time this has happened to me but it has been the first time in a while. i noticed that whenever the car would go into limo mode it would either have to be raining or snowing. well yesterday it wasn't raining or snowing and as i was going to the store the car went into limp mode. i could turn it off and turn it back on with no problem. when i got out the store i tried accelerating in neutral and there was zero response. as soon as i would put it in 1st, i accelerate it and it would actually accelerate. from the previous times the car has gone into limp mode i did not try to accelerate while on neutral. i read up a bit and people were saying to check the grounds. i have done that and that's what fixed my problem the first time. it lasted well over a year with no issues. when i got home i used vagcom to diagnose it and it popped up this code.
008504- accelerator position sensors (G79) / (G185)
P2138 - 008 - implausible correlation= MIL ON
i did search for a answer but to other that have this problem say they had the 02 sensor wires short circuit, causing the ecu to fry. i have had none of this things happen to me as i wasn't messing around with my 02 sensors. another thing. i am not that familiar with vag com and only know the basics since ive only had it for a few weeks. is there any test you guys can recommend on me doing via vagcom that can help pin point the problem. i was not getting weird rpms or anything like that just the car in limp mode with the epc and traction control light on. i can try and check the grounds again to see if that's what causing the problem but i don't think that is the case. but just to be on the safe side in case there is a ground that i don't know about, where are the grounds on this car? much help is appreciate it. oh yeah almost forgot to mention. i ended up going to the store again and when i was in the parking lot i was shutting off and turning on the car a few times. the lights went away and haven't returned and also limp mode is gone. but still i know something is wrong and i want to fix it. thanks in advance for all the input.
