    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Most Functional Overhead Valve Spring Compressor
    What are we using for valvetrain removal on 2.0T & 1.8T heads? I saw this on ebay LINK but am not sure if it does the job easily. I've previously used those large c-style clamps/compressors but I found them very difficult to work with. Any thoughts on this tool or any other suggestions?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Denio24 View Post
    That's the exact compressor I used the last two times I disassembled my head. It should be possible in theory to use them with the head on the car, but I did it on a bench with the head strapped down with a ratchet strap. It also helps to slip a pipe over the handle to give you more leverage to compress the springs.
    -Adam
    Jan 23 2013
    Chicago
    Wonderful. Can't wait to build my head once I get some $$ in the reserve. By the way, have you looked into this? CLICKY
    Mar 24 2013
    Oakdale, CT
    Yes, I was actually just talking to Issam about it the other day.
    -Adam
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    I recently installed this on my car, still wanting to pull it off to check on it
    I have had it for about 1000 miles now.
    2006 A4 6MT | JHM Stage 1 Flash | Cam Follower Conversion
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
