Results 1 to 3 of 3
    Oct 02 2015
    Ireland
    Brake light switch help!
    Hey guys,
    I used vagcom and got an error on my ABS because when im in heavy traffic and i leave my foot on the brake pedal like 1 min in holding down the abs and esp light both comes on the dash.. I did the scan and said it was my brake light switch front? Anyway i bought a new one there and i installed the switch.. I disconnected the other one and just put new one in and twisted like it should.. Now when i press the brake pedal, straight away the both lights light up? Im confused.. Please can someone help? I have the car still apart so i have access to the switch. Thanks!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It sounds like the brake pedal position switch is out of adjustment. I had the same problem with my upper clutch pedal position switch. I ended up using my multimeter to check continuity on the switch until I got it to connect/disconnect at the proper position.
    This thread should help: Clicky click®
    Oct 02 2015
    Ireland
    Perfect!
    Yeah i was messing around and i realised it wasnt in the correct position so i twisted it more and it clicked again and bayum! All working.
    Cheers buddy.
