Results 1 to 7 of 7
    Active Member Two Rings bots10's Avatar
    Nov 16 2015
    Ballston Lake Ny
    New Guy. Vag Com / VCDS Recommendations
    What's up guys,
    First off that squealing issue I had, has been rectified. Turns out it's a brake issue.
    I am now in the market for some sort of vag com /vcds cable and software. As some of you know I'm coming from subarus and all of this is very new to me. I was reading a little bit and seems like Ross tech is the way to go, but I didn't know if there was alternatives out there. I would also like to be able to use the software on my girlfriends 08 rabbit if possible.
    Sent from my SM-G900V using Tapatalk
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Ross-Tech is the only way to get a legit one. They're expensive but worth it. The HEX+CAN USB one should work for both of your cars. Also definitely get the unlimited license.
    Sent from my iPhone 6 using Tapatalk
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    +1 Ross tech is by far the way to go.
    Apr 19 2014
    Long Island
    Agreed ross tech is great and their fourm and support are amazing
    Deactivated Two Rings
    Oct 29 2015
    Bay Area CA
    I agree about Ross tech , if you got the money you should have one around. But if you looking for a little bit more handy whether you choose to get a Rosstech or not, definitely jump onto the Carista app. From what I see it looks like a promising future and investment for the company. $46 for both the Carista dongle and pro app. Only reason you would need a rosstech is to play with your coding, all the other fancy stuffs, Carista does I believe if I'm not wrong.
    Mar 24 2014
    ^ This could be another alternative depending on your use case. Carista can do most of the feature enabling and it can read and clear basic check engine faults. If you want to be able to do more in-depth things (HID conversions, complex fault codes, changing LED brightness, data logging, etc) you'd need the actual VAGCOM cable and software.
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Quote Originally Posted by Project Quattro View Post
    I agree, with all the things you can do with Ross-Tech cable it is well worth the original investment and will pay for it self in the long run.
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
