so after replacing all of my vacuum lines with silicone/034 lines, i've been getting a persistent p0441 CEL...i've been researching and while there are a few threads on AZ, most of them aren't very specific...
i've never gotten this code prior to changing out my lines (i didn't delete any part of the vacuum/PCV system), here is what i've done so far:
1. confirmed all check vavles are flowing in correct direction
2. confirmed all hose clamps are tightened down
3. replaced n80 valve
the hard lines in the EVAP system are pretty pricey so before i start systematically replacing all of those lines i was hoping someone had any ideas to fix this stubborn bitch of a CEL...
on the ross tech wiki one possible solution is "Check Pipes between Tank Breathing and Throttle Body", what exactly is the wiki referring to? this CEL is eating away at my soul...
if i were to replace the hard lines in the EVAP system it would cost me over $300 on GAP...FML, i was about to piece together my GTRS but am refraining from doing so until i get this CEL resolved...the shitty part is that there are soooo many components to the EVAP system that using the scientific method of replacing shit until the CEL goes away will quickly become cost prohibitive...
so pray tell...other than a faulty n80, what other solutions are there to p0441?
