Results 1 to 23 of 23
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Electric Noise When Turbos Spool
    My turbos make a strange "drill" type noise when they spool sometimes, this is at pretty much any RPM and isn't the infamous "dentist drill." The noise is rather quiet. Any ideas? 108k, bone stock.
    I'll try to get audio if it happens again.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    sounds about normal
    mine do the same with 207k on them
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Quote Originally Posted by PaperToast View Post
    sounds about normal
    Ah good, it scared the hell out of me originally. Do you warm up/cool down after driving?
    2003 Audi S6 Avant
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    don't get into boost when the engine oil temp hasn't moved off the bottom of it's gauge and don't boost right before parking, though right before parking is not so bad since we have an electric water pump to keep things cool afterwards. it even says to not drive hard when oil is cold in the user manual.
    but yes the light whistley noise when the turbos spool up is normal
    2007 A6 Avant 3.2L Black/Black, 265k miles
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Quote Originally Posted by estomax View Post
    Thanks, there's also a whistle noise that happens always when I accelerate. Not sure if that's normal either..... I blame turbo whistle. I always warm it up before I drive and cool it down after hitting ze boost though.
    2003 Audi S6 Avant
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by R490 View Post
    always, especially now in the winter time.
    it might boost like mad when cold, but only do that if you like pulling the motor and rebuilding everything once a month
    cool down is more critical in the summer when its hot, not so much in the winter
    Rockin' the Rockies
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Ah, that's probably why your k03s have lasted you 200k :)
    Sorry that I'm a 2.7t n00b, but how about the turbo whistle? Hope you don't mind the questions
    2003 Audi S6 Avant
    Jan 16 2009
    if yours sound like what mine do at beginning of this video then its perfectly normal.. whistle noise as it spools and then just a whoosh.
    https://www.youtube.com/watch?v=R3cfXviPM14
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Yup, that's the noise! I personally like it, even if something is broken.
    2003 Audi S6 Avant
    Apr 29 2009
    Quadzilla
    Longmont, CO
    once everything gets to operating temp, its barely noticeable
    Rockin' the Rockies
    Sep 11 2009
    NE
    I don't buy that whole get it to operating temp OCD... fact is that 99.999% of these were bought by people who only knew where gas and brake pedal is and fine nuances of getting car to operating temp was far beyond their concerns...yet the cars somehow survived it and we are driving them currently without problems!
    So long you let the car to warm up enough for coolant temp needle to start moving from cold (that's at about 60C coolant), you can stomp on it as much as you want. You need the coolant needle to start moving to ensure that pistons and rings are warmed up. Mind you that this is probably 15 minutes before the oil needle even spasms from its lower reading.
    I've done 100s WOT pulls on my car observing only the coolant rule (it takes car about 2-4 minutes to move the coolant needle depending on ambient temp) and that's on quite insane power levels, on both K04 and now Tial 770s @ 36psi (had them on for last 4 years).
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    Quote Originally Posted by julex View Post
    It's true most owners have no idea about warming up and cooling down the oil. But you then take the example of two replacement sets of turbos and use that to support your position? What about the original K03s? And if you had left in the K04s and not gone to 770s? Who knows how beat to crap your K03s/K04s would be by now from you not warming up and cooling down the oil?
    Why take that risk? It's minimally annoying to keep your foot out of it and the revs below 3K until the oil needle moves. I go one step further and wait till it hits 175F on the gauge, and let it drop down around or, preferably, below 200F before shutting down. Do I know for a fact that having gone through this routine over the past 7+ years of ownership has helped me get to ~160K on original stock K03s? No, but the general consensus among enthusiasts and engineers is that it does make a difference. I see no reason to ditch it now, and plenty of reason to recommend it to others.
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Quote Originally Posted by JediJoker7169 View Post
    That exactly. I love my A6 and I'm not afraid to baby it a little to prolong the life of the turbos.
    2003 Audi S6 Avant
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    I bought my a6 with 158k.. and im 95 percent sure previous owner just drove her.. didnt love her. So... my snails are probably shot or half way there but its okay.. Saving for stk
    Sep 11 2009
    NE
    Whatever rocks your boat, if I could warm her up properly I would but as is, my commute is less than 10 miles so the oil just barely sits at operating temp for a minute or two before she shuts down. It is not practical to me to do it "right". Now, the K04 turbos lived on my car for couple of years and when shaft play was measured at time of sale, it was well below BW's "factory new" specs for both radial and axial shaft play. 50k later and the dude who owns them now is still riding on them just fine.
    Far more important than letting the oil warm up is to use right oil (0w-5w at most and thickest you can run for hot range, so at minimum use 5w-40) and change it frequently (big NO to 10k intervals audi set these cars for!) and most importantly use formulation with > 1200ppm of ZDDP which most modern oils fall well short of (0w40 Mobile 1 for example should not be used anymore as they reformulated this oil due to emission reasons to much lower ZDDP, I think it sits at about 800ppm now and it used to be 1200ppm when audi certified it). ZDDP keeps your valvetrain alive.
    Now, this is a super funny little fact for you:
    Did you know that taking the same oil, it will support MUCH LARGER load on bearings when it is completely cold than when it is at operating temperature? And that what keeps lifters and tappet camshafts alive is not oil itself but ZDDP zinc-oxide layer on top of these parts? - kind of against of what you were thinking, isn't it?
    The fact is that you will never hear anybody talking about turbo failure due to cold engine boosting as turbos get hot immediately after start up, but cracked rings etc is not unheard of if you don't let the engine to work lightly for couple of minutes - so that these critical parts heat up. This will happen well before your coolant gauge even moves.
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    I feel ya on that thing about operating temp, my commute is four miles round trip. I usually let it warm up ~5 minutes or so in the morning and less than that on the way home, as the weather is warm. It's probably not too great on the engine though, but I rarely hit ze boost or shift above 2.5k.
    2003 Audi S6 Avant
    Aug 04 2009
    Glen Ellyn, IL
    What oil do you use Julex?
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Sep 11 2009
    NE
    Quote Originally Posted by 4rings2turbos View Post
    Right now Castrol Edge Titanium 0w-40 Euro (with titanium for wear additive). It is properly certified for our engines. You can also use Rotella T6 if you wish, both available at Walmart for hair above $20 per 5 quart jug.
    Sep 30 2015
    Wow thats a good price for 5 quarts. Usually runs me around 45 for 5 liters of ravenol 5w-40.
    I do not doubt rotella and castrol work fine.. Reason I use ravenol is because it has some of the best cold starting performance compared to other oils in its class. most of the time its marketing bs by each company to promote their product, but these guys have been confirmed by various oil reviews. we run castrol in my sisters hyundai and my moms kia. my father runs mobil i believe in his dodge ram, and for my moms weekend benz, also ravenol. neighbor pours in liqu-moly into his gti.
    But for 20 dollars a jug.. damn maybe i need to get on that wave.
    Aug 25 2015
    Wisconsin
    How do you cool down? Just get out of the car and turn it off? (In Wisconsin so its essential for me to warm up in the morning.)
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by Iamdoinitrite View Post
    let it idle for 30 sec or so, in the winter the cold air does the rest
    Rockin' the Rockies
    Sep 30 2015
    For the last 5-10 minutes of your drive, dont build boost, just take it easy. By the time time you park your car, wait maybe another minute if you like, turn her off.
    if you are paranoid about overheating then install a turbo timer
    Aug 04 2009
    Glen Ellyn, IL
    I use Liqui Moly Leichlauf but haven't really done all the research I could to see what's optimal for my region. I am not bashful about high top dollar for top oil.
    @fourings | Build
