    Aug 30 2014
    United States
    Thermostat Housing lower O-ring
    On the AWM 1.8T motor, does anyone have a VW/Audi part number (or just a size so i can order on amazon) for the O ring that is inside the hose that attaches to the lower side of the plastic thermostat housing?
    I replaced the housing for sh** and giggles when I was doing flange and other things, but I didn't replace this O ring. It's leaking from their now...
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Aug 30 2014
    United States
    ^ Thats the o ring that goes on the thermostat where it sits in the block.
    The entire plastic thermostat housing has another end on it. That is a quick disconnect type connection into a hose that comes from below (radiator hose maybe?). Inside the tip of that hose is the oring that I need.
    Oct 31 2014
    NH
    Oh my bad thought thats what you were looking for.
    2014 Audi S4 - 6MT
    2000 Audi A4
    Jun 30 2008
    Erie, Pennsylvania
    If its the same size as the ones on the radiator, it would be 32 x 4mm. More info here
    http://www.audizine.com/forum/showth...1#post11205464
    Seems like there is 2 sizes of those connectors: the ones at the radiator, and the ones for the heater core. Not sure if the thermostat one is a match for those, or if it is some 3rd size.
