Results 1 to 7 of 7
    Sep 14 2005
    NC
    Passenger side headlight purplish after oil change.
    Took my car into eurowise for an oil change. Noticed after that my headlight on passenger side is purplish.
    Is this a sign of the bulb failing??
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Yes or your car contracted pink eye
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Not good! The dreaded high intensity conjunctivitis
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Four Rings alphaVR's Avatar
    Sep 12 2012
    Stage 3 F21 B5 S4
    Cleveland, OH
    definitely sounds like pink eye
    FTWLTBDWICTW
    21 Toyota Tacoma TRD Sport | Daily Driver
    17 Audi S3 | Nano Napalm | The New Hotness
    00 Honda Civic | Track Rat[/SIZE]
    Jul 04 2012
    Woodbridge, VA
    I'm sure it was just a coincidence.
    Sep 14 2005
    NC
    I'm thinking so too. So how do I check what it is???
    Dec 03 2009
    PNW, Washington
    No real way to check. You can replace the bulb. IIRC it's just a standard D2s bulb. People used to run the DDM tuning HID kits back in the day when the OEM bulbs and ballasts died. Maybe there's better options nowadays.
