    Veteran Member Four Rings rmacc's Avatar
    Mar 20 2014
    South Jersey
    Rear LSD options
    Okay so I'm looking to go rwd. I don't want to hear about how it's stupid, or that I shouldn't take an awd car and make it rear blah blah. Just looking for all the current options for the rear diff.
    As far as I know, there is the jhm diff, which I'm sure is good and everything and definitely has a great price, but I'm not to keen on helical diffs. There is also the wavetrac LSD but I don't see myself spending 1200 on it.
    I saw a thread about a b5 s4 that had a Porsche 944 turbo LSD in it and only required minimal modification. Is there anything like this that would be close to being "drop in" for b7s?
    Thanks
    Ryan
    instagram: ryxnn
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    First off how are you planning to stop sending power to the front wheels? Why dont you go with the 4-1 center diff instead of killing all power to the front. Its not like the car is set up for rwd so you still have an engine in front of the axle. Might as well use some torque vectoring for cornering. Not many people opt to go completely rwd on here. If i were you I would look into an lsd paired with a 4-1 center diff before ruining your quattro. I think you may be surprised.
    Mar 24 2013
    Oakdale, CT
    You just have to remove the front axles and IIRC, weld up the center diff.
    -Adam
    Mar 20 2014
    South Jersey
    Yes, that's all you need for rwd, but that still doesn't solve the open diff problem in the rear
    Ryan
    instagram: ryxnn
    Veteran Member Four Rings Lastsummer's Avatar
    Nov 25 2011
    2021 B9 Audi SQ5 Black Optics
    Grayslake, IL
    I believe that AUDIHERE said it best...
    If youre looking for more handling and cornering capabilities and thats why you are wanting to go RWD, then a good lsd paired with the 4:1 center dif will do just that. It will change the characteristics of how the car corners and give it a more rear bias. Also adding in a good rear sway bar.
    The problem with the B7 is is that it was not designed to be rwd. The motor is in front of the front axles and still makes it pig heavy up front. Not really ideal for rwd.
    Either way, best of luck in your searches. Interested to see what you do.
    2021 B9 SQ5 - IE Turbo Inlet, IE CAI, 034 Motorsport Stage 1 ECU/Stage 2 TCU, O34 Strut Brace, 034 F/R Sway bars w/ end links, 034 trans bushing & insert, 034 RSF inserts, 034 rear diff inserts, 034 lowering links
    B8.5 Audi S4 - Monsoon Gray - EPL Stage 2 - Single Pulley, EPL TCU, ECS Carbon Intake, ECS Mid-pipe, Magnaflow Catback, ECS Drivetrain/Trans inserts, ECS Lower Control Arm Brace, CR-15, S5 Peelers, H&R sports, Bilstein Shocks
