Results 1 to 29 of 29
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Rear Sway Bar advise
    So my S4 has a neuspeed sway bar installed by a PO, but I noticed there are no reinforcement brackets installed... I do not believe the subframe has any cracks but am worried that the larger bar will eventually create some..
    The options I am considering are inspecting the subframe more thoroughly and if no cracks found installing 034 brackets.. Or just going back to the stock sway. Is the neuspeed bar worth the cost of reinforcement brackets? Just looking for some input, I'm leaning toward just buying the brackets.
    Hope I don't need a new subframe.. Lol
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    You'll be fine
    If no cracks are present, and/or if the bending is minor, run the 034 brackets and forget about it.
    RSB is one of the best handling mods in this car, imho
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Dec 14 2014
    PNW
    Will do, I'll check for damage then just order the brackets...
    I can't tell between my stock A4 other than the S4 just overall being better.. Maybe I'll throw the stock A4 bar on the S4 and give it test..
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    Ill buy that neuspeed sway bar from you and i have an extra stock sway bar i can give to u
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    Quote Originally Posted by Wagonholic View Post
    You'll be fine
    Bad/unsafe advice IMHO. My subframe tabs literally tore off with a hotchkiss bar and no brackets. Not a rust or other issue, that thin metal is in no way strong enough to support a larger bar and hard driving. Be smart,safe and run some type of reinforcement.
    Dec 14 2014
    PNW
    Yeah man. Turns out it has the neuspeed bracket on it, I was looking for some kind of billet reinforcement like 034's..
    Jan 01 2011
    Nor cal
    Quote Originally Posted by cjt671 View Post
    I run the 034 brackets , they do the job fine I'm sure the neuspeed ones work just as well. Not much too that part to change
    Dec 14 2014
    PNW
    Quote Originally Posted by killerkali View Post
    Yeah they look like they mount pretty much the same way, doubt it would make a difference to swap in the 034 one..
    On the topic of Swaybars, any reason to upgrade front? And if so would rears need to be larger than 19mm?
    Mar 01 2014
    Los Angeles, CA
    Never told him not to run the reinforcements. If there's no damage, then no harm no foul. If there was damage then obviously he should solve that first. I run the reinforcements (034). The reinforcements end up transferring the load anyway through the brackets which is good.
    Justin
    #YEengineering
    Mar 01 2014
    Los Angeles, CA
    Neuspeed brackets are fine. Run them, forget about it, and enjoy the car. Won't make any significant difference by switching to the 034. They do the job fine
    Justin
    #YEengineering
    Mar 01 2014
    Los Angeles, CA
    Honestly don't even bother with the front. It'll just cause the front to push more and make our (very prevalent) understeer worse.
    Obviously it's more complicated that this, but the basic rule for suspension/sway bars is the following
    Stiffer rear: less grip in rear, more in front, front grips, rear rotates, leans towards oversteer
    Softer rear: more grip in rear, less in front, rear grips, front pushes leans toward understeer
    Stiffer front: less grip in front, more in rear, rear grips, front pushes, leans toward understeer
    Softer front: more grip in front, less in rear, front grips, rear rotates, leans towards oversteer
    If anything, you'd want a thinner/softer sway bar in the front lol
    Justin
    #YEengineering
    Aug 24 2014
    Newport Beach, CA
    I'm going to install a set of Hotchkis sway bar brackets on my car along with the H&R bar that's already there. The Neuspeed brackets as Justin said will be fine, another thing to consider adding are the metal rear sway bar end links and spherical front sway bar end links. Those two things make a tangible difference and don't change the balance of the car.
    2024 M3 Comp xDrive
    Dec 14 2014
    PNW
    Quote Originally Posted by christianb5s4 View Post
    I'll put those on my list. Thanks man🏽
    Dec 14 2014
    PNW
    Any specific ones for front? I know 034 makes em, but remember reading something about WRX endlinks
    Aug 24 2014
    Newport Beach, CA
    You'll definitely appreciate how much more precise they make the car feel. The front spherical end links really tighten up steering response and feel as well.
    2024 M3 Comp xDrive
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    Do not upgrade the front sway. Do the rear as for reasons above. If there is enough people I'm sure 034 can be convinced to run a group-buy for us.
    Dec 14 2014
    PNW
    Have the neuspeed bar already
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Yep, 2002+ WRX rear endlinks fit the front of our cars. I use Agency Power AP-GDA-210 spherical endlinks, and have been using them for 26k miles now (about 3.5 years), but also in SoCal where there's little rain.
    They started squeaking a little maybe 4 months ago, but didn't really have any slop. About 3 months ago I sprayed some silicone lubricant (mostly just to make sure it was them which were squeaking) and they've been fine since.
    034 sells spherical front end links which may fit better, but cost $144 + shipping. The spherical WRX end links can be had for ~$102.60 shipped here:
    http://www.ultrarev.com/Agency-Power...FQISfgodv-0Jbg
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 14 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    I installed a nuespeed rear sway bar and I didn't feel any difference in handling I was thinking of getting the 034 rear sway bar is it true nuespeed made two different bars strength
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by erykv1 View Post
    Eh, I respectfully disagree. If the rear bar is big enough then a larger front bar shouldn't make the car "push" any more than it did before, and in fact, it will actual help turn-in and body roll significantly. That's why Hotchkis sold them as a pair for the longest time... If you want to extenuate oversteer (at the cost of a sloppy front end), then run the rear bar only, but a front bar really makes the car so much more responsive IMO. I'd at least try it both ways to see what feels better.
    Note: The "correct" solution is through appropriate spring rates, as sway bars are really just a bandaid, but nobody in their right mind would run 1000/1200 springs around town.
    Quote Originally Posted by uponone nogaro View Post
    FWIW, some of the Neuspeed RSB's aren't much bigger than stock at 19mm, and even the 25mm ones are on the small end. That's about as big as my H-Sport FRONT bar, as the H-Sport rear is 35mm!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Dec 14 2014
    PNW
    That was more of my thinking, in my question about the front bar
    Would a larger front bar coupled with a proportionally larger rear bar create a worthwhile improvement in the overall handling of car.
    Mar 08 2007
    Mr. Worl-Wye
    I think so, especially if you only have a so-so suspension. Since the front end of these cars is so heavy it really helps keep things flat under cornering, and makes steering input noticeably sharper. But, to each their own... Try it both ways if you can find a cheap front bar somewhere, but definitely get some reinforcement brackets for the rear bar.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Dec 14 2014
    PNW
    I'm on H&R coils, I wouldn't say they are bad as I've definitely ridden in worse lol.
    Maybe I'll just bite the bullet and buy a front/rear kit or look for a set used
    Sep 14 2011
    Bay Area CA.
    Ya it looks that way I went from a pencil to a small sharpie
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by BITRBO View Post
    You are 100% correct about the "correct" solution being running stiffer springs, because stiffer bars reduce suspension independence. That's why most of our cars with stiff rear bars love to become tripods on steep driveways.
    I always thought our front bars were pretty massive stock already, and if you watch the video you can see my car does have fairly minimal roll and does corner pretty flat. But to each their own, never said it was a "bad" mod, just didn't feel it was worth it considering a larger front bar would require an larger rear bar.
    Turn-in can be also addressed with a more aggressive alignment as well.
    Justin
    #YEengineering
    Aug 24 2014
    Newport Beach, CA
    Agreed on alignment, after I got mine done post H&R coilovers, it was night and day. They did a mild street/sport alignment, gave them Stasis' guide to different alignment settings and told them to find a happy medium.
    2024 M3 Comp xDrive
    Mar 08 2007
    Mr. Worl-Wye
    The stock front bars are big on these cars cause the nose so heavy. Not sure if you ever drove your car hard while it was still on the stock suspension, but I did and I can't imagine how bad the roll would be with a smaller front bar.
    So you're still going to feel a good bit of body roll even with a good alignment. I have a fairly aggressive alignment, 800lb springs up front AND the H-Sport FSB (22mm) and you can see how much body roll I still get:
    (this is a FAST right-hander at Homestead that "feels" flat in the car, but you can see how much weight transfer there actually is)
    I think you need at least 1000F/1200R springs to keep the car flat under hard corning (without a big front bar), but again, nobody in their right mind would run that on the street, so sway bars are the obvious solution.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    What tire are you running in the picture?
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Mar 08 2007
    Mr. Worl-Wye
    245/40/17 Hankook RS3's on 17x8 Kosei KS T1's. Fantastic tire for the money.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
