    Established Member Two Rings ColumbusAudiA4's Avatar
    Mar 15 2011
    09 Yamaha FZ6R
    Columbus, OH
    Question 2013 Q5 Prestige but want the SQ5 instrument cluster
    Does anyone know if someone has swapped clusters around yet? Im looking to pickup a 2013 Q5 3.0T fully loaded with every option out there but its for my better half. I have owned other VAG models and swapped clusters on my CC but wanted to know if anyone swapped clusters to get the nicer looking SQ5 cluster. It looks like new its about $1,200 which isn't horrible but wasn't sure if it would be plug play. I'm sure it would be very similar to the swap on my CC i did. Any input would be great! Hope to be on here soon more often! Spend most of my time on the ClubTouareg forums right now.
    2008 Touareg 4.2L FSI, Alaska Grey with Teak interior, Air Suspension, Added rear heated seats, Heated Steering Wheel, Android KGL-7402, Rear view camera and parking sensors, Adaptive Cruiser Control with Front Assist Retrofit, Side Assist/Lane Change Retrofit, OEM Tow package, 35% Llumar matching tint, 20" Carrera Wheels, 275/45/20XL tires. VAG Com by Ross-Tech, Yellow Porsche F/R Sway Bars
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    You need your SKC number. Which no one will give you, so the dealer needs to do the swap.
    B7 RS4 mugello
    B7 S4 moro
    Q5 meteor
    Mar 15 2011
    09 Yamaha FZ6R
    Columbus, OH
    OK thanks, I thought that was only if it was a used cluster. On my CC if it was brand new, it allowed a one time entry of miles and all the info (options) and after that it required dealer SKC. Hmmmmm ok i'll keep that in mind. Thanks!
    Jul 10 2014
    Prestige Q5 is pretty close to loaded SQ...check it out
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    Is there a difference that I'm not aware of? White needles and SQ5 gauge faces?
    There was a guy who replaced his ugly low-res red display cluster with a facelift one with a high-res color display, so try to find him to PM. He posted about that in a facelift headlight retrofit thread either here or on AW iirc. Good luck.
