Results 1 to 11 of 11
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    RS4 B5 OEM and Performance parts for sale
    Hi
    I've had enough of the 2.7T platform so I am moving away from it and probably going for a 07K swap so therefore I have lots of fun and OEM stuff for sale from my engine bay. I will keep the pieces updated, first come first served. All parts are plus shipping. Images of some items are here: http://nerd.hu/rs/ If you need any other items from the engine bay, ask.
    OEM parts
    - carbon engine covers => 320 EUR (SOLD)
    - carbon painted Y-pipe (vtn) => 300 EUR (SOLD)
    - RS4 fuel rail => 140 EUR (SOLD)
    - RS4 airbox (flap removed) + accordion + MAF => 200 EUR (SOLD)
    - RS4 throttle body + intake manifold + TBB + pressure pipes => 900 EUR (SOLD)
    - Brand new carbon canister + N80 valve => 100 EUR
    - RS4 ECU => 220 EUR
    Performance parts
    - Brand new Girodisc 380mm B7 RS4 discs => 900 EUR
    - 034 big bore silicone Y-pipe Hose Set. => 165 EUR
    (https://store.034motorsport.com/y-pi...-silicone.html)
    - Complete 034 motorsport billet fuel rails with AN8 in and AN6 out
    including all hoses in the engine compartment + 034 FPR housing,
    Fits perfectly without any modifications. => 300 EUR
    - A set of 960cc Bosch EV14 injectors with adaptors and spacers to
    fit the RS4 fuel rail. => 320 EUR
    - Evolution Racewerks intercoolers modified for RS4, bigger in-out with carbon shrouds => 1000 EUR
    - Complete TFSI Coil conversion => 200 EUR
    - ASJ heads (no-cracks) with 034motorsport lifters and perfect condition cams and new tensioners => 1920 EUR
    - Custom RS6 hybrid turbos with 57mm pressure pipes and modified OEM intake pipes to fit an RS4 without modifications. The turbos are capable of at least 600bhp on on gas. Specs are: OEM RS6 turbine housing, 2.7TDI compressor housing (bigger). 45-50mm turbine, 46.5-60mm compressor. With 1bar wastegates. The kit includes the pressure and intake pipes as well. => 2000 EUR
    - 3" downpipes with RS4/RS6 flange to fit any kind of turbos. => 400 EUR
    - Custom tubular exhaust manifolds (in: 37mm, out: 41mm, wall: 3mm) => 600 EUR
    - TTV flywheel with a B7 RS4 modified clutch kit, 8 puck disc, ceramic. => 1000 EUR
    - ARP head studs (used only once) => 300 EUR
    - 034 Motorsport motorsport mount pair (street density) => 200 EUR (SOLD)
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    Will you sell just the rs4 airbox?
    Senior Member Two Rings 01silverS4's Avatar
    Oct 19 2010
    junk
    Dallas, TX
    Interested in the carbon engine covers. PM sent.
    2001 Silver Stage 3 S4 - sold
    2001 Casablanca Stage 2 S4 - sold
    2014 Panther Black SQ5 - sold
    2016 Monsoon Grey A3 E-tron - current
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Quote Originally Posted by gmdiluca View Post
    With the accordion and MAF, yes.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    These items are provisionally sold, pending payment:
    - RS4 fuel rail
    - motor mounts
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    Is the y-pipe Oem rs4 covered in carbon fiber or is it the 034 carbon fiber rs4 style ?
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Quote Originally Posted by Yuppie View Post
    OEM.
    Feb 14 2005
    If buyer backs out let me know. Prices you listed, does that include shipping?
    Senior Member Two Rings BDidz's Avatar
    Sep 18 2014
    Duluth, MN
    Ill take the carbon engine covers if they're not sold already.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Replied to PMs.
    Also I have now two sets of RS4 blocks for sale. Both require machine shop work and oversize pistons, perfect for 3L.
    Both sets include: RS4 AZR block (with main caps obviously) + upper oil pan + lower oil pan + front seal. No crank.
    These are $1200 shipped to the US per set.
    Jul 20 2013
    Nashville, TN
    Hello,
    I am interested in this:
    Who manufactures this? Does it include all components, including the coils, spark plugs, harness pigtails to the coils, and the ICM delete pigtails (2)?
    Are they they plug-and-play pigtails for the ICM delete or will they need to be soldered?
    Thank you,
