Did a quick search, not much. Wanted to ask before I went in and broke the seal just to see. Can the 2.8 30V intake be rotated 180 Degrees for Front mount T/B. Now, ignore the P/S pump. That is to be removed since this chassis(2004 RX8 GT) has EPS and not HPS. Most Evac stuff will be removed or modded, and this will run on a Stand Alone. Just thought I'd ask in case anyone for sh*&s and giggles tried it during a mod or rebuild. I do believe I may have enough room behind the engine(RWD config) for plumbing, but a front T/B will make things a bit easier. And I'd rather not go to the 2.7TT Mani since I'm staying N/A(already close to trans max TQ) and the N/A mani is factory tuned for N/A use.
