Results 1 to 15 of 15
    Active Member One Ring EricHarveyy's Avatar
    Apr 30 2014
    Diverter Valve or Blow off valve
    I haven't seen much discussion around here on what people prefer or what they think benefits there car the most. I was looking at a new diverter valve because it seems to be the most logical and least obnoxious while driving. But are the benefits even that noticeable? Does anyone have any recommendations on what diverter valves or blow off valves to get and why?
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by EricHarveyy View Post
    http://forums.vwvortex.com/showthrea...ter-for-my-1-8
    http://jettajunkie.com/vw-jetta/show...alve-on-a-1.8T
    http://forums.vwvortex.com/showthrea...ve-vs-BOV-1-8t
    http://www.audizine.com/forum/showth...Diverter-Valve
    In summary: 1.8T is designed to run in recirculating mode. With BOV you are just dumping metered air out. I'm not knowledgeable enough to tell you what that is doing to your engine over time, but when metered air gets lost and the ECU still supplies fuel based on it, you will run rich.
    There are valves like the Forge Splitter that are hybrid and let you adjust the amount of recirculation vs dump. I have one on my car. I haven't tried others to tell you whether it works better or worse. It does make a nice sound, but because of it everyone wants to race me at every intersection. So, I will be switching to an OEM 710P diverter valve soon.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Running a BOV dumps metered air (once measured from the MAF), which essentially creates a boost leak.
    The ECU is looking and accounting for air that was in the system, and no longer is.
    A DV is the way to go.
    Aug 26 2005
    Manual or Auto trans? With a tip auto trans, the DV has practically no effect on the throttle response, since the throttle does not snap closed during gear shifts.
    Vorsprung durch Technik
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    Def go with a diverter valve. I would recommend GFB's DV. They all around make some really nice DVs which are popular for various applications. We have a GFB dv in every one of our cars here
    https://www.moddedeuros.com/audi/a4/...iverter-valves
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Nov 10 2015
    Northeast Ohio
    You can run a bov on later b6s (maybe all Im not 100% sure.) I believe since they have a wideband o2 and adjust afrs based on that. So technically it wouldn't be unmetered air anymore. However, there's no benefit to a bov other than a "pssssss" sound during shifts as the original setup is meant for a DV.
    Sent from my B1-730 using Tapatalk
    Apr 01 2007
    houston texas
    Quote Originally Posted by OneSlowA4 View Post
    This is incorrect. Air enters through the MAF the is dump - boost leak. To run a BOV you'll need to be running a MAFless tune (for BAT applications).
    Nov 10 2015
    Northeast Ohio
    Quote Originally Posted by texasboy21 View Post
    My b6 definitely has a wideband o2 and will adjust afrs regardless of what the maf says. You're correct that its unmetered but after driving the car it won't affect afrs as the ecu will adjust based on o2 readings which are all that matter lol. Look it up. I'm almost 100% positive.
    B5s however have to run a mafless tune for a bov or afrs will be rich.
    Nov 10 2015
    Northeast Ohio
    Basically unless you're running a big turbo and high boost numbers your stock DV is fine. If you want to upgrade stay with a DV unless like I said you're running a high boost application. There's no need for a BOV. I'm not disagreeing with that texasboy21.
    Dec 05 2007
    The WB 02 sensor calculates your lambda (AFR) on your exhaust to make sure you have proper combustion. When the throttle body closes, that air being deflected back (blow back) by the throttle body flapper never made it's way into combustion chamber, let alone the exhaust for the 02 sensor to monitor it. With a BOV, that blow back that was already monitored by the ECU and MAF is now released into the atmosphere and the readings of your air intake is your system is now off. With that missing air, the ECU still thinks it's there. Till the primary 02 sensor senses you running rich (happens quick) due to already adding x amount of fuel because it was expecting y amount of air in the combustion chamber, your fueling won't be corrected.
    With that being said, you can most def run a BOV on these cars as long as it's "closed at idle". Is it not suggested and frowned upon? Yep! Mostly because you want to do it for that ppppsssshhh sound all the cool kids are doing. And with that being said, I also run a bov but run a bigger turbo mafless application. But, would perform much better with a closed loop maf with dv system.
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    Want noise? Get s splittr otherwise get a dv
    2.7 swap in progress
    Nov 10 2015
    Northeast Ohio
    Okay I was mistaken. It adjusts afterwards it doesn't fully correct it. Either way it can be done without harm but is pointless.
    Is there even a point to change the dv without other mods anyways? There's no performance gains.
    Sent from my SM-N910V using Tapatalk
    Apr 01 2007
    houston texas
    The harm is your fueling will be off, which affects performance.
    A DV is not a power mod, its a wear item. The factory DV uses a rubber diaphragm that over time (or with increased boost pressure) tears, causing incorrect operation. The aftermarket DVs use a metal spring a piston that cannot tear, are serviceable/rebuildable, and offer the availability to change to a softer or stiffer spring. WIthout any other mods on the car (mainly a tune) there is no need to go with anything other than OEM.
    2019 SQ5 Prestige
    Nov 10 2015
    Northeast Ohio
    \thread lol
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    Mafless tune or a blow through maf. Which is what I'm running. Does measure the air till after the fmic.
