Results 1 to 20 of 20
Thread: Front subframe
    Established Member Two Rings Bumpo411's Avatar
    Jun 09 2015
    Portland, Maine
    Question Front subframe
    I'm looking for a front subframe for my Audi A4 B6 3.0 Quattro, 6-speed manual with sport suspension. The one I have on my car now is rotting I can buy brand new for $933 (cheapest i've found) but I really don't have the money because I need to replace my power steering rack at the same time. I was looking around and found one on eBay from Germany. The part number for my subframe is 8E0399313BG and with that, I was able to find this
    http://www.ebay.com/itm/8E0399313M-8...WE8Ze#shpCntId
    but it says it's for a 1.8T, but the part numbers match.
    So my question is...Can I use a 1.8T subframe on my 3.0? Would the subframe in the link, work for my car?
    Feb 27 2011
    Winnipeg
    even if you have the sport suspension I thought the number ended in BD, the Audi dealer told me all the MT ones were the same 4 cyl or 6, I have a good MT subframe if youre interested.
    here is the trans codes related to each subframe PN, I have one ending in BD if youre interested, let it go cheap.
    Jun 09 2015
    Portland, Maine
    According to Genuineaudiparts.com, the part number is 8E0399313BG and the subframe without sport suspension is 8E0399313BD, but I don't know the difference but I'm guessing there has to be with different part numbers
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by Bumpo411 View Post
    you need PR code 1BV and trans code ENL ENN or EYQ to get the BG p/n subframe according to my etka
    Nov 29 2007
    '06 Cayman S, '04 A4 3.0 USP, '85 UrQ
    Scottsdale, AZ
    There are plenty of used ones for sale on eBay. Find one that looks the same as your present one (some have extra brackets and/or missing or different mounting tabs) and you're good to go.
    P.S.: If you want a performance upgrade, find one from an A4 Cabriolet, because they have solid aluminum bushings instead of rubber/metal ones. To wit:
    Or if you want to maintain your car's OEM NVH performance, you can also use 3M Windo-weld urethane to fill the gaps in the OEM rubber/metal bushings, going from this:
    to this:
    FYI, tubes of 3M Window-weld can also be bought on eBay for around $18/tube, which is a much better deal than the $25+ Autozone gets for it, and one tube will do both the front and rear subframes (provided they're both of the car and ready to go at the same time, because once the tube is open, it must be used ASAP since it starts to cure immediately.)
    While you're in there, another trick you can take advantage of is to use a large bolt, nuts, and washers through the alignment tab on the subframe to tie all the components together and minimize its lateral movement under load:
    While the subframe tabs are fairly weak and flimsy, they are still strong enough to limit the amount the subframe can walk under load. (FWIW, I've had this mod on my car for 8k miles so far with no problems.) They will also limit the subframe's ability to move vertically under load as well, but at the expense of slightly increasing NVH.
    And whenever you need to align the car afterward, you can easily remove them to install the subframe centering tools that should always be used before you start adjusting the tie-rod ends.
    Jun 09 2015
    Portland, Maine
    Quote Originally Posted by seanf86 View Post
    I'm not sure what my PR code is but my transmission code is GJV
    Feb 27 2011
    Winnipeg
    PR codes are in your trunk on sticker by spare tire.
    I did some checking since you didn't post what year your car was, I used 2002 and 2004, 2004 just says any car with PR 1BV gets pn BG, pn BD goes to cars with 1BD 1BE and 1BA.
    Regardless, I've got a subframe that will work for you if you're interested, came off 02 1.8t quattro 5MT
    Nov 29 2007
    Scottsdale, AZ
    Quote Originally Posted by Spike00513 View Post
    For centering tools, would any old rod or pry-bar work?
    I've always used a pair of deep-well sockets that fit perfectly and hold them in place with a zip tie, so I've never the need to buy a fancy tool for this. As for moving the subframe around, the usual tools -- pry bar and rubber hammer -- have always been sufficient for me.
    Can NVH be countered w/ better shocks, Koni FSD maybe?
    No, because the NVH is transferring from the engine to the subrame and then into the bodyshell, which bypasses the shocks.
    @100k mi + on sport subframe, mine has a lot of noticeable flex.
    What would you recommend, metal cabriolet, or window-weld (I have TigerSeal)?
    It depends upon what you're trying to achieve, how much additional NVH you're willing to accept, and your budget. Swapping to a used, low-mileage subframe is probably the easiest solution, but seam-welding your existing subframe and adding some reinforcement to it then stiffening the bushings to your taste is probably the most cost-effective option. I would only install a Cabriolet subframe if you need a new one anyway and your insurance is paying for it (or you're competing in the car and class rules require an OEM subframe), otherwise, I'd modify your existing one and add 034's aluminum bushings if you're tolerant of NVH or Windo-weld them if you're not.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    If you have a little time to wait, I'm parting out my 3.0 6-speed A4 with sport suspension.
    -Tim
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    im in the market for a front subframe for my 2003 a4 avant 1.8t quattro if anyone has one for sale.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by alien_brain View Post
    Need to specify trans, I have a 2002 1.8t quattro 5mt one for sale
    Jun 04 2013
    SE MI
    ok yeah 5mt. will the 2002 fit the 2003? did we already talk?
    tranny makes a difference?
    Feb 27 2011
    Winnipeg
    Maybe we did, if we did i don't remeber, auto trans have tabs on subframe for mounts to bolt to, manual trans don't.
    Jun 04 2013
    SE MI
    hey thanks i think ill attempt to find one here...
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by Audii-Dudii View Post
    Didn't know this and your link is dead. Any idea if the bushings are just sold separately?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Nov 03 2011
    All Over!
    For those with 3.0 tip. or pre-2003 (01E) 6-speed manual, you can use the subframe from a B5 2.8 Quattro. Direct fit.
    If you have a later B6 with the 02X 6-speed manual, you can still use the B5 subframe, 1.8T or 3.0, you just need to cut / grind off the B5 gearbox mounting tab/s That won’t be needed on a late B6.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Interesting that you front would be rotting before the rear.
    I'm on the hunt for a rear one just to completely refresh my rear setup.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Jun 09 2015
    Portland, Maine
    Still looking for a front subframe. According to Audi USA parts, the front subframe I need can also be found in these vehicles.
    Feb 21 2024
    Prague
    Is that true? I have same issue. I have later A4 b6 1BV sport suspension with 1.8T Q and I have another subframe from earlier b6 with gearbox mounting(spare car was a4 b6 1.8T automatic, quattro with 1BA suspension)
    I quess, they are interchangeable.
    Audi A4 b6 2004 1.8T BEX Quattro
    Abarth 500 2009 99kW
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Quote Originally Posted by lukydm View Post
    You may have found this already.
    I was planning to pull my subframe, but have opted to postpone this for now.
    https://www.audizine.com/forum/showt...ibility-Thread
