Results 1 to 6 of 6
    Established Member Two Rings Keaney's Avatar
    Oct 09 2014
    Uk
    Apr coolant performance system on A7 / A6
    So I know the kit is mainly for the s4 and one other person has fitted it to a A6. But has anyone else fitted a APR coolant system to a A6 or A7 and did you need to make any modifications to the fitting kit?
    Mar 17 2015
    Australia
    Mate I'm wondering about this as well.
    I know someone has fitted them on an A6 where they had to play around with the plumbing.
    Oct 09 2014
    Uk
    I'm ready to stage 2 mine and thinking do I need it, I don't track the car but then I know reducing the heat will improve the engine efficiency anyway.
    Really want to stage 2 it too but I'm tempted to hold off till I get this then stage 2 it.
    Apr 09 2015
    phoenix az
    I would like to know this as well especially since I live in phoenix
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 02 2014
    Las Vegas, Nv
    Stage 2 with air intake and downpipes will work fine for daily driving. If you plan to track the car and drive like an ahole 24/7 in vegas or phoenix summer heat (115 plus weather) then yes you should upgrade your cooling system. I'm stage 2 in vegas heat and the car is fine for daily driving but when you try to drag race your car in 100 degrees, run after run you'll suffer power loss....
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    AKA: Yoshi123
    Oct 09 2014
    Uk
    Yeah I live in the uk, 30c is very rare here and the car had a roc euro intake with awe exhaust so it's ready for stage 2.... This cooler just looks tempting!
