Results 1 to 4 of 4
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    P0100 & P1857 (Mass Air Flow & ABS)
    I've started reading up on the issue but some time ago my CEL & ABS lighted up, same time, i think. So P1857 is a no communication error... and can be a little tricky to diagnose as it can pertain to many things? I did a scan and turns out I also have P0100. Question is, what could cause these two codes to light up at the same time despite being unrelated? Coincidence? I guess first step to diagnose would be to clean MAF sensor see if it makes a difference and check wiring to MAF sensor. I should also add that the car runs fine.
    Code:
    Address 01: Engine        Labels: 06F-907-115-AXX.lbl
       Part No SW: 8E1 910 115 G    HW: 8E0 907 115 D
       Component: JHM 93STG1 TFSI     0010
       Revision: 5EH15---    Serial number: XXXXXXXXXXXXXX
       Coding: 0104010A180F0120
       Shop #: WSC 06325 000 00000
       VCID: 2643BDD291DCF90E07-8072
    2 Faults Found:
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - MIL ON
                 Freeze Frame:
                        Fault Status: 11100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 192480 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 21.0°C
                        Temperature: 15.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.065 V
    008584 - Bank 1; System too Rich at Idle
                   P2188 - 008 -  - MIL ON
                 Freeze Frame:
                        Fault Status: 11101000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 192494 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 739 /min
                        Load: 26.7 %
                        Speed: 0.0 km/h
                        Temperature: 90.0°C
                        Temperature: 9.0°C
                        Voltage: 13.589 V
    Readiness: 0000 0100
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004526
       VCID: 2E5345F2B92CB14EFF-807A
    1 Fault Found:
    18265 - Load Signal
                P1857 - 000 - Error Message from ECU
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 61
                        Reset counter: 40
                        Time Indication: 0
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x6222
                        Hex Value: 0x0028
                        Hex Value: 0x0196
                        Hex Value: 0x0001
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Oct 24 2015
    Perth, WA
    Yeah id check the MAF, it may be malfunctioning causing the voltage issue and therefore the rich conditions...
    My respray thread
    Jan 24 2013
    Chicago
    I guess the ABS module monitors the MAF input for air flow for whatever reason. MAF connection was loose. Solved.
    Oct 24 2015
    Perth, WA
    Ok cool, well done.
    My respray thread
