I have read ever forum about shaking while doing 55 n up but nothing, I have had two tire shipp and a Audi mechanic look at it n spend about 2k on the car still no help!! I drive a 2006 b7 s4, this is kind of long but shit is crazy!
It started when I got a flat ($$$) on my stock wheels I put a spare on n the car did shake at high speed but did wasn't the same as it is now.i kept the spare on until over the summer I got a set of 19" wheels with spacers $$$. The shaking is was crazy at like 55-65 so when back the to the tire shop(1).The tire shop(1) who put the tire on my car said that it might be brakes so I got both the brake and rotors done at the same time and also bought coil over at the same time $$$ . Once i got the brakes done and the suspenion put on I got the car back n still did the shaking so I took it too another tire shop(2) and had then check if the tires where balanced properly the first time and got a balance done . They said balance was a little off but they did it again $$$. So I got the car back still a lot of shaking talk tire shop (2) they say it's the spacers so remove spacers and drive no fix. I take of the 19" and the spacers and put the stock wheels on doesn't fix the shaking. So I take it to a Audi specialist Drive Auto Works in NJ, pay the man to check out the car completely,problem; car needs new tire rod links on both sides and new problem needs valve cover gaskets $$$$$$$$$. They fix it those problem but the shaking so they say it's my stock wheels are bent $$$. so now I buy new wheels use my old tire and still the shake.
Pleas help !!!!!
