Results 1 to 14 of 14
Thread: Rear Brake DIY
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Rear Brake DIY
    Can someone list the link to a DIY for brakes...The fronts are easy, its just the rears I am concerned about. I have a VAG-COM just wanted to know the steps in VCDS and wrench sizes. I looked and searched the forums but could only find front DIY
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I followed the instructions directly from Ross-Tech. Hope this helps :)
    http://wiki.ross-tech.com/wiki/index...ng_Brake_(EPB)
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Nov 19 2011
    Rhode Island
    what is the need for a battery charger? Can't I just keep the ignition on after opening the parking brake, changing the pads only takes like 10-15 min? Or can you just open the parking brake then turn off the ignition then once done turn on and then close and cycle? Also what are the bolt sizes?
    Mar 26 2010
    US
    Quote Originally Posted by dizzlesizzle View Post
    Depends on how solid your battery is. The rear brake pad swap is the first time I got a message on the dash display of a weak battery.
    2019 RS5 Sportback
    Veteran Member Three Rings Chandler's Avatar
    Jun 07 2014
    Recycle Bin
    South East
    I took awhile to do the brake change for the rear - I cleaned my calipers and replaced my lines too. If you are just doing a pad swap, you should be fine.
    "People who think they know everything are a great annoyance to those of us who do."
    Apr 15 2014
    Ohio
    13 mm socket
    I just changed all my pads and painted my calipers last night. I put the parking break in service mode (VCDS calls it "bed lining" or something, but it's under the parking break section), then turned the car off so VCDS was disconnected. I had no problem changing the pads. I left it off all night while the caliper paint dried. Then this morning i put the breaks back together, hooked up the VAG Com and turned off the service mode ("stop bed lining"). No issues.
    Jun 07 2014
    Recycle Bin
    South East
    Quote Originally Posted by Webnerd3 View Post
    13 mm socket
    Pictures of calipers with the wheels on? I've debated painting mine. But I don't want to damage the S4 badges... and I think painting the rears would look pathetic because of how small they are!
    Sent from my SM-G900V using Tapatalk
    Apr 15 2014
    Ohio
    I'm still learning how to do images on here... so be patient with me.
    [IMG][/IMG]
    With rear wheel on:
    Side View:
    Other side:
    Front:
    Front Close Up:
    The S4 badge is a plate that you pry off before you paint, so don't worry about that. Just stick a flat head in there and gentle pry it up. There are 2 posts that hold it in place.
    Jun 07 2014
    Recycle Bin
    South East
    Thanks for the images. Maybe I'll do it next time I'm bored and it's getting dark out so I can leave the car over night.
    Nov 25 2013
    dallas/Texas
    Hi I have an 2010 A6 Quattro and about to do my rear brakes as well. A year ago I purchased the online manual for like 200 bucks. Its been great and it includes software for the VCDS. Unfortunately I don't have any cables. I wanted to do the job this weekend. I live in Dallas, TX. Would there be a local place to get the cable
    Nov 25 2013
    dallas/Texas
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Quote Originally Posted by heycap View Post
    http://www.audizine.com/forum/forumd...php/62-Central
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Nov 19 2011
    Rhode Island
    13 mm socket
    So there is no need for a battery charger then bc i don't have one. I was planning on doing the same thing, use VCDS to open the parking brake, turn the car off, once finished, turn the car back on. I just wanted to confirm there is no issue or problems with turning the car off for about 30-45 min while I do both side. Every forum i read, people have been saying you need to keep the car in acc while doing the brakes??
    Apr 15 2014
    Ohio
    I did not use a battery charger. I had the car in accessory mode, started up VCDS and opened the parking break, turned the car and laptop both off (closed out of VCDS on the laptop), completed my work on the brakes, waited around 9 hours, then turned the laptop and car back on and closed the parking brake.
