Results 1 to 10 of 10
    Jan 15 2010
    Santa Barbara, CA
    Banging noise in trunk when going over sharp bumps - anyone found a fix?
    Recently I've started to notice a banging/knocking noise from the trunk when going over sharp bumps. It's not a metallic bang, but more of a hollow knock. I have TTX Ohlins, so no, it's not the DRC. :) It sounds like it could possibly be the rear deck flapping slightly, or the cargo area cover acting like a giant drum and making a knocking noise.
    I've added foam under the cargo cover and in between the styrofoam bits underneath, but that didn't seem to help. Before I continue to chase it down, I was curious if anyone has experienced this, and found a fix.
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    With my PSS9, I had a nut come lose at the top mount which also stretched the bolt. Similar sound but once recognized and replaced and loctite added it's totally gone.
    Jan 15 2010
    Santa Barbara, CA
    Ok, I'll have the shop check for that when I'm getting a carbon clean next week. Fairly sure it's in the trunk, but it did start after I had the TTX's installed, so that's entirely possible. Thanks for the tip.
    Jan 27 2013
    Quote Originally Posted by forbiddenbeat View Post
    No problem, the sound drove me nuts, and I hope you will find it soon.
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    Bury the body and the noise will stop
    Ghost
    Jun 18 2009
    Phoenix, AZ
    Check all the suspension mount points to make sure they're tight, maybe (including the upper shock mounts)? Something in the trunk bouncing around like the battery or something?
    2017 Camaro SS 1LE
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by FWP! View Post
    The TTX uses a different type of upper mount compared to other kits or stock shocks. It's less prone to this type of noise.
    Check your endlinks and lower shock mounts.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    And I was just going to suggest that the hooker wasn't dead :)
    Jan 27 2013
    The question is - was it worth it? If so, chill, and keep driving!
    Jan 15 2010
    Santa Barbara, CA
    Lol @ dead hookers. :)
    I drove on a fairly rough road yesterday, and am fairly sure it's the suspension. The seats were folded down, and it was fairly obvious the noise wasn't coming from the trunk itself. The battery is tight, so it's not that. I even reached back and opened a rear door while driving to make sure it wasn't the door seals creaking.
    The car is getting a carbon cleaning at 034 Motorsports on Thursday, so I'll ask them to check the suspension as well.
