Results 1 to 8 of 8
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Limit of stock fuel system 1.8T
    How far has the (non return style) B6 1.8T fuel system be pushed?
    How far can it be pushed with just a larger pump?
    I would like to run 400 cHP on E85 without having to convert to full return style.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Jun 08 2008
    Calgary AB Canada
    I'm running a GT3076 with the stock return system and an Aeromotive pump, I should be putting down around 400-450chp. E85 will require more fuel than that, but I imagine you're still ok.
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by onceover View Post
    450 cHP equates to roughly 300 cHP as far as fuel flow is concerned. I need to flow the equivalent of 600 cHP pump gas to make 400 hp on e85.
    Sent from my Nexus 7 using Tapatalk
    05 Golf TDI
    Dec 05 2007
    Get a proper tune and it's the other way around. 600chp e85 equivalent to 450chp pump.
    Nov 10 2015
    Northeast Ohio
    In terms of fuel he needs the same amount as a car making 600chp on pump gas. You need roughly 20% more fuel using e85.
    Sent from my B1-730 using Tapatalk
    Dec 05 2007
    I know he needs more fuel. But if he is looking for 400chp, that is already a modified vehicle and he is going about it the wrong way. The new FT on E85 can get him what he wants and more, for example (guy posted his dyno close to 400whp on e85). No need for a 600chp pump gas application. Just proper tune and fueling. If anything, the stock 5/16" lines would be the restriction at that point. But I doubt that, also (should be close to -6an).
    Nov 10 2015
    Northeast Ohio
    Yes I agree with you there I was just saying if he wants to switch from pump gas he's gonna need more fuel. If he's already got the mods to make 400chp on e85 then fueling shouldn't be an issue besides injectors and a tune.
    But I don't think switching the fuel system is TOO hard of a task and there's nothing wrong with preparing for bigger numbers in the future ;)
    Feb 20 2010
    Brighton, MI
    Back to the question on hand: what power can be made on the stock B6 1.8t fuel system?
    05 Golf TDI
