Results 1 to 6 of 6
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    c5 a6 interior lights pulsing
    hey guys, i am fairly sure i know what i need to do, but figured i would make a record here of it also. my 2003 A6 had problems with the drivers door lock not latching all the way and i replaced it with a used assembly off a newer allroad. it worked fine for a bit but one day as i was sitting at a red light the interior lights start pulsing.
    https://www.youtube.com/watch?v=cFN3QU-poM8
    the only codes i get are these (i know my right rear door latch is going bad too because it doesnt set the interior lights on when i open it nor show it on the dash that the door is open, but i havent messed with it).
    01559 - Drivers Door 58-10 - Can't Lock - intermittent
    01562 - Rear Right Door 59-10 - Can't Unlock - intermittent
    a new driver door latch is 364$, but that is where i am headed i feel like.
    Marko
    2007 A6 Avant 3.2L Black/Black, 265k miles
    May 16 2008
    South Texas
    Sounds like water ingress.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by estomax View Post
    Marko
    http://www.audiworld.com/tech/elec96.shtml
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jan 16 2009
    at this point the driver door sensor is always reporting the door as open and interior lights stay always on and there is an annoying beep sound for first 30 sec while driving the car, thanks for the audiworld link i will try the quick fix, i am not so sure i want to take the time to take apart the door switch though, at that point i'd rather replace it.
    cheers
    Marko
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    http://forums.quattroworld.com/allro...s/230337.phtml
    watch the videos, then decide before buying a new latch
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jan 16 2009
    yah removing the latch is no problem since ive done it a couple times already but i am getting to a point where messing with used latches is not worth it. i fixed the annoying beep signal by cutting the blue wire on the door microswitch that's accessible by popping the door card back. now my driver door simply doesn't register opening the door, beats having the lights on and the annoying beep though.
    i will investigate if i can do the easy fix of routing the blue wire from microswitch to door harness or if i need to replace the whole thing.
    cheers
    Marko
