Results 1 to 3 of 3
    Sep 14 2005
    NC
    Would the ecs stage 3 Porsche brake kit....
    Would it clear our stock 17's? Also is this kit just plug and play??
    Thanks
    Jul 04 2012
    Woodbridge, VA
    Which stage 3 kit? I think they have a couple out. One uses the 17z 330mm calipers and the other uses a Tuareg caliper.
    Cannot speak to the Touareg calipers, but the The 17z 6 pots version will clear with stock Avus 17s. It is plug and play depending on if you have aluminum or steel uprights. The aluminum ones have an extra "bump" you have to grind down. I can't speak on that process but it seems simple enough.
    In my opinion, you'd be better off saving yourself $1000 by building it yourself. I can help you out with finding the abundant parts.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    How you thought about a Stoptech kit? Bolt on and direct fit. They also clear the stock wheels just fine. For the money I never found it was worthwhile to stress over not know if it works or not This is me speaking from experience.
    Check them out for yourself here!
    http://vag.excelerateperformance.com...t/g-52574.aspx
    Greg
