Results 1 to 16 of 16
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Abs not working due to one wheel
    It snowed last night and I have to drive 45 miles to get home. It's thus far been quite sketchy! My front left brake just decides to come on when it feels like it as far as I can tell.
    I have vagcom but not with me. I gernaded an axle a few months ago and ever since then my abs light has been on. The new axle has the wheel speed ring that's clean and I've taken my sensor out to check for any debris on it and it was clean. I've also reset the codes for it but it just comes back.
    I know it's probably difficult to diagnose without having codes, but could I maybe just buy a new abs sensor or sumthin?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    If you have VAG-COM, then diagnosing is definitely the best way to go. Throwing parts at it can be quite the crap shoot.
    With VAG-COM you go into the ABS module. If you have Ross-Tech VCDS you can graphically display the measured speed of each wheel (while driving), and this can help you pinpoint [for sure] which wheel it is. Then you can check out that sensor, replace or push in as needed.
    2001 Corvette (C5) Z06
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    The sensors can be really picky about the distance from the tone ring.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It is probably the sensor.
    And keep in mind, Ebay sensors are awesome for the price.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Nov 14 2011
    NW
    Thanks for the replies. Good to know ebay sensors work! Can I check my sensor gap somehow? I don't have my Bentley manual with me but does it say what it's depth is supposed to be?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    There's not really a good way to measure sensor depth, even if there is a specification.
    What I do, is push the sensor in so it starts to make light contact with the tone ring (verified by spinning the wheel). Then back it off maybe a millimeter and verify it no longer makes contact.
    You can try this in the interim if you feel confident which wheel it is.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    There is a spec for sensor distance (something like .2mm to .8mm, can't remember off the top of my head). It involved using some heavy stock paper or like 3 pieces of printer paper. Put them in between the sensor and the ring, push on sensor till it contacts the paper, and then you are done. Don't know who came up with this method, probably the guys in the white coats. But it works with every adjustable sensor I've done.
    The other way is the way MetalMan said. Push sensor till it contacts, rotate out slightly till there is no more contact.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Nov 14 2011
    NW
    Good gravy that's not much gap. I probably put it in a decent amount which could be a cm for all I know. I pulled my abs fuse and made it home. My pipes froze and burst, so after I sort that out i'll jack it up and spin it/ push it it.
    Thanks for the help! I would've just replaced it and probably still had the issue.
    Apr 03 2014
    17 GTI Sport
    Holy crap I hope the house and you are okay. I think when the sensor is too far away it gets tricked into thinking the wheel is just going balls out and so it keeps applying the brakes because it doesn't sense the wheel slowing down.
    I use the push down then pull back until you can't hear any scraping from the sensor like Metalman last time I had to mess with them and it worked great, no problems.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by vrmm View Post
    This is definitely a big issue! My wife's friend bought a house in Colorado about 1.5 years ago, came back to SoCal for Thanksgiving, and came home to a flooded house. Burst pipes... due to them not leaving the heater on (they're from California).
    But they got a new kitchen, flooring, and other new things from insurance out of it.
    Jun 30 2008
    Erie, Pennsylvania
    If it's *applying* the brakes, that is the EDL (electronic differential lock) kicking in. The EDL works to apply brakes to a spinning wheel, sending the power across the axle (left to right, or vice versa) to the wheel that is stopped (not spinning).
    In your case, both wheels are turning, but one probably has a faulty (or too far spaced-out) sensor. As such, the EDL sees one "spinning" wheel and one "stopped" wheel and it KICKS IN (Yo!). So, most probably, it will be applying brakes to the wheel *across* from the one that has the sensor issue. So if it's applying brakes to the left front wheel randomly, the sensor issue is likely with the right front wheel.
    Notably, EDL mostly works on take-off, up to 15mph (or was it 25mph?). So if it's pegging the brakes while you're cruising at 40, the above scenario is probably not accurate.
    Nov 14 2011
    NW
    I got my pipes fixed. Luckily it wasn't too bad. My roof is dumping water into my bathroom now! There was a wind storm last week in the great ol' Spokane and my house got hit with two trees. No power led to the frozen pipes. And a big branch went into my bathroom. Thought I fixed it... Guess not :p My 47 willys truck stopped the second massive tree and took it like a friggin champ! That's what I was most worried about ;) priorities...
    Back to the sensor... I logged wheel speed and found that whichever is in the first column only read 1 km/h the whole time. Would that be drivers front? I wiggled the sensor out and it was a bit dirty but nothing crazy. I could never get it to stop my wheel from spinning. I used a rubber mallet and believe it is in as far as it can go. After testing it like that I pulled it out a bit more with no success.
    Thanks for the info walky. Under 15 sounds reasonable. Given that there is no speed input to one sensor I would assume I shouldn't need to worry about the issue being on the opposite side?
    I found the sensor on eBay for 9$. Sound about right or is that too 'ebay'?
    Jun 30 2008
    Erie, Pennsylvania
    The measuring block data trumps all (especially Walky's nonsensical musings).
    $9 sensor sounds like ebay "just right" to me.
    Nov 14 2011
    NW
    I'm assuming this will make it inoperative? I put the new one in but haven't driven yet...
    Nov 14 2011
    NW
    Well it didn't work. The abs axle ring is intact albiet dirty. Like worn down metal with a bit of black grease tossed into the mix. It's not excessively worn down. I would imagine it would work fine, but does any amount of contact cause it to not work?
    I did not clear the abs code. I'm gonna assume it's recommended that I do? It was still staying at 1km/h on the drivers side. I'd imagine it would have output code or no code if properly functioning.
    Walkyyyy Should I be looking into your 'opposite side' scenario or not since it straight up told me which sensor it is?
    Jun 30 2008
    Erie, Pennsylvania
    No, you've found the problem based on the obvious damage there.
    If there are metal particles in between the tone ring "teeth", then it can screw with the waveform. It's not going to see the all-important "edges" of the metal teeth. You should try to clean that out if you can. If you can't get a reading from the sensor via the module, a live scope of the sensor would be helpful to get to the bottom of things. Most people don't have a scope, but nowadays a smartphone can do basically everything:
    https://retronics.wordpress.com/2012...-oscilloscope/
    http://oa.onyx3.com/signals.html
    Another quick method is to use a Digital Multimeter in A/C volts mode while spinning the wheel. Compare to a working sensor to get a baseline, then try the problem wheel. You don't get to see waveform quality or shape, but you get to see if you have some signal or not.
