Results 1 to 7 of 7
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Battery state VCDS - What does it mean ?
    Im from Norway, its cold at the moment.. around -6 celcius at night.
    When I park my car the MMI shows 100% battery, following day it shows from 30-50%. Im running a Blackvue which is connected to a power magic pro.
    Anyway, Ive tried to unplug the Blackvue but the battery still drops from 100% to 30-50% the following day.
    Sometimes Im not able to start my auxiliary heating because of low battery, it wont start if its less than 30% I believe.
    I trickle charged my battery for 30 hours but it seems like im experiencing the same drop in battery the following day.
    I did a battery battery measure in VCDS both before and after trickle charge.
    BEFORE:
    AFTER (I forgot to hit go on 018, if necessary Ill provide a new picture):
    Im not sure how I analyze this, did it get any more juice from trickle charge or should I get a new battery ?
    I see my battery capacity shows 14Ah (!) .. the current (OEM) battery has 105Ah - I should get a new battery ?
    Veteran Member Three Rings S4Phantom's Avatar
    Jun 10 2012
    How old is the battery
    2011 Phantom Black S4 Prestige Titanium Pkg., Sport Diff., Alu Kreuz, Milltek Non-resonated exhaust with oval tips, AWE Carbon Fiber intake, Stage 1 GIAC, Black powder coated Titanium Pkg wheels
    Nov 13 2006
    Oslo, Norway
    May 2011
    Jun 10 2012
    If you're having trouble I would just replace it. My car is a 2011 and I'm not having problems yet but am thinking of changing my battery out at my next service. In my experience working in a repair shop battery's don't really last much more than 4-5 years
    Nov 13 2006
    Oslo, Norway
    Thanks, so if I understand correct.. (im a total noob on batteries).
    The battery should not drain as much as it does overnight, even though its cold ?
    Ive never experienced any problems starting the car, just auxilary heating and by observing the battery level on my MMI.
    Jun 10 2012
    Yeah I don't think it should be going THAT low overnight even with the cold. Some one else may be able to chime in but 30% seems extremely low
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by S4Phantom View Post
    Just replace your battery, you have already new in garage! Car will start even with 10% specialy petrol ones. If battery will not keep capacity 100-30, something is draining battery or battery dead soon, its 4,5 years, Norway and with aux heater which is killer for battery.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
