Results 1 to 22 of 22
    Active Member Two Rings Ramzi's Avatar
    May 28 2015
    Oakville ON
    Does anyone make a Honeycomb Grill for sline bumpers.
    Why is it so hard to find a honeycomb grill without the license plate filler for a B7 s-line/s4 bumper. I dont want to spend 600 bucks buying an RS4 grill, so what are my best options?
    This is the exact look im going for but for the B7
    Thanks,
    Jan 19 2014
    Geo Metro
    Delaware?
    http://nickscarblog.com/diy/how-to-f...o-filler-plate
    Sent from my STV100-1 using Tapatalk
    May 28 2015
    Oakville ON
    Quote Originally Posted by maslows View Post
    Seems like a lot of work but I guess its my only option
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Anyone get a price on what this mod costs? Since you're out two grills (RS6 and A4)?
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Nov 13 2011
    b7 s4 avant
    Quote Originally Posted by JDillon15 View Post
    you can save yourself some bucks by buying an aftermarket rs6 grille. That's what mine is. As for the the b7 grille, as long as you don't ruin it when you cut it up, how are you out two grills?
    I drive a truck now.
    Jul 11 2014
    Chicago, IL
    I would be hacking up two grills. The RS6 for the mesh and the A4 for the frame. I wont be hacking up my OEM one, so I'll have to buy 2, and probably sell the one currently on my car. But the initial cost is still two. Idk, it's how I did the math in my head.
    Ball park, mind telling what you ended up spending on this mod? Did you follow the guide on Nick's blog or find another?
    Nov 13 2011
    b7 s4 avant
    I see what you're saying. For me, I bought the rs6 grille used here on az for around 100 bucks. I had also bartered with another az member (A4Effort) and acquired his oem titanium grill in exchange for taking photos of his car lol. So I still have my S4 grill somewhere in my backyard at least. The only other money I spent was on epoxy, some super glue to "tack weld" the honeycomb to the b7 surround and some filler because I cut too much. So maybe around $130, give or take.
    And yes, I used the guide on the blog. If I had to do it over again, I would definitely try to make some kind of template of the b7 grille before I cut and trim the rs6 honeycomb. I ended up trimming a little too much off of the honeycomb in the bottom corners when I was trying to fit it in. Since it's not flat, and has a decent amount of curvature, it can definitely be tricky trying to get it just right. from up close you can definitely see where I had a hard time with it. I was thinking of something like chicken wire, since it's so flexible but can sort of hold a shape, or even cardboard. It would have been REALLY helpful.
    If you zoom in on this picture, you can just make out some of the filler on the bottom. I'm also pretty impatient and have no skill with that sort of thing so it looks a little rough lol. Someone like Noel who works with plastic and fiberglass can do much better than I did. I should have spend some time to clean that up but I was fed up lol
    3D8A3463.jpg by jj bonilla, on Flickr
    This is the best shot I have to show the curvature of the grill, and why a template would do you well.
    11057862_10156002319685468_1654130178866365192_o by jj bonilla, on Flickr
    Jul 11 2014
    Chicago, IL
    Thanks for the tips. It sounds like you and I are similar when it comes to DIYs - I'm sure mine will have its fair share of imperfections as well.
    Active Member One Ring I3jorne's Avatar
    Aug 29 2016
    Stockholm
    I thought this would be an appropriate thread to bump with my question... Can I use an RS6 ''style'' grill for the C6 A6 or do I have to get the actual RS6 grille? I've seen that some of the Rs6 style grilles say ''Doesn't fit S6/RS6''?
    Apr 24 2016
    California
    Quote Originally Posted by I3jorne View Post
    Probably a similar thing to our A4/S-Line/S4 situation. The grill won't fit, but the A6 grill might be big enough to get enough mesh to fit the A4 grill. Best thing to do would be to ask the C6 forum for a measurement of their stock grill and make sure it would be enough to cover your entire grill frame
    Sent from my iPad using Audizine mobile app
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Nov 13 2011
    b7 s4 avant
    Rs6 style is just code for an aftermarket grille and should be fine
    Aug 29 2016
    Stockholm
    Okay thanks guys.
    I'll double check in the other sub-forum
    -A4 B7 2.0T Quattro
    Veteran Member Three Rings mr_Law's Avatar
    Feb 13 2014
    bronx ny
    I have a non S-line and I made mine using the DIY on Nicks Blog.
    LLTek.com sells the Grille for S-Line bumpers
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by mr_Law View Post
    $700! Yikes...
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Mar 11 2018
    MI
    Old bump, Any new news on aftermarket mesh grills that are direct bolt on for s4 and s-lines?
    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Quote Originally Posted by Mustangridah View Post
    2nd
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    I don't understand why this is so difficult for manufacturers... There are hundreds for non-sline and not a single one for s-line.
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
    Senior Member Three Rings All_Black_A4's Avatar
    May 20 2017
    2x B7 S4 Avants.
    Calgary, AB
    Agreed. It's not like there's a huge difference between the 2 bumpers. The number of B7 S4 and A4 S-lines driving around cant be that much smaller than non S-lines.
    No doubt some AZer has the production numbers of both lying around
    2007 Audi S4 Avant 6MT: JHM Intake manifold and spacers, JHM Long tube headers and FI exhaust, JHM light weight flywheel, JHM light weight crank pulley, JHM Short Shift trio, 034 motorsport engine mounts and Trans mount, Apikol snub mount, Apikol rear diff mount, H&R lowering springs, Hotchkiss rear sway bar, RS4 grille and Maxton carbon fiber side skirts, Full wrap W/Inozetek Midnight purple.
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    I picked up an aftermarket RS6 full mesh grille on eBay for $100, then kept my eyes open for an S-line grille that was less than perfect, finally found one for $85 shipped. Frame fully intact chrome surround was broken. I’ll either swap my Ti surround over or look for a good surround and wrap or dip it. Unfortunately I’m moving into an apartment for at least a year so this project will be shelved until I get another garage. But at least I have my materials 😀😀😀😀
    May 17 2014
    Raleigh, NC
    why, you can buy them on ebay for $100? complete lol
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by rodgertherabit View Post
    Your not gonna find an s-line mesh grille on eBay for $100. They are all for non s-line.
    Sent from my VS995 using Audizine mobile app
    Feb 13 2014
    bronx ny
    Actually I made that long before they were available to buy.
