Results 1 to 7 of 7
    Junior Member Two Rings
    Jun 07 2015
    Hose identification w/ pics , evap or vac. ?
    I came in contact with this line(circled pink)while changing out the spark plugs on the d/s . Pulled on it to hard and it snapped . Looks like it starts just under the abs act. & runs along the valve cover & to a check valve at the rear of the motor . If anyone has a part#/diagram or even what its called its appreciated.
    [IMG][/IMG]
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    It runs to a vacuum reservoir in the DS fender, iirc. It along with that multi-input check valve & n249 provide a source of vacuum to help speed up your diverter valve actuation.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    What year car and which area of the part snapped? There are two parts to this hose. Since this line runs to the front driver side fender as well. A picture of the snapped part would help. They sell this part, only thing is you have to get the right part for the year of your car.
    Oct 26 2011
    CA
    If you need the line you circled in pink. Which is the EGR Tube with Check Valve. I believe you will need part # 078145733G
    Jun 07 2015
    Yeah broke right around the timing cover area . Xalents thank you that's exactly it , its a 2002 s4
    Oct 26 2011
    CA
    Quote Originally Posted by SilverS488 View Post
    No problem, the part number above will work for your 2002.
    Jun 08 2014
    Vancouver, Washington
    You don't need to buy a whole new piece though! My check valve broke as well, so I bought another check valve for like.. $20? And then put on all new vacuum hoses on its connections with hose clamps. I'll take a pic later. Ive had no issues with it and its much cheaper.
