Results 1 to 40 of 47
    Feb 25 2014
    Texas
    Aftermarket Clutch Break-in Issues
    Hey Guys,
    I had the stage III clutch and lightweight flywheel below put in the car a few weeks back.
    http://www.ecodetuning.com/store/aud...-3-0-4-2l.html
    I have put about 300 miles on the car since install, about 70% of those are city miles. I understand the break-in is 500 city miles so I am about halfway there.
    The stiffness is great, like stock, but every time I engage 1st gear from a stop, no matter how I engage it, the car shudders. When the car is cold, there is no shudder at all. As soon as the car warms up, the shudder gets much worse. Is this normal? The guy who installed my clutch has been a master mechanic at Audi for 20 years and has many aftermarket clutch systems under his belt.
    Any insight on this? Will it go away after full break-in?
    Thanks,
    Mickey
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Sep 13 2015
    North
    Likely not, with a little more RPM you should be able to avoid the shudder.
    Feb 25 2014
    Texas
    Quote Originally Posted by neverfastenough View Post
    I've attempted engaging 1st gear at various RPM levels and they all have some form of shudder, obviously some more than others.
    All these folks on here with aftermarket clutches and only one response?
    10.65 @ 129mph
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Did you replace the OEM pressure valve that eases engagement with SS line when you upgraded your clutch/fw? link http://www.audizine.com/forum/showth...all-6MT-owners
    I would also venture out to say it could be your lwfw, but when i had one on my B5, i would get chattering not shuddering, and it was mostly when the AC was on...
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    It should get better.. I still get shudder though, not as bad as when I was breaking it in.
    I have to keep the revs a bit up if I want to avoid it.
    But yes normal.
    C7.5 S6 P+ Mythos Black
    10.894@126.29 103oct Stage 2 100 File/RACECHIP
    11.284@121.29 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 11.978@117.71 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    I notice this too on mine. I'm on my 2nd week with it in and I have about a little over 200 miles on it so far. It seems to shudder when I don't give it enough gas. I don't notice it when I give it more gas. But I know it should get a little better when its broken in.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I hate clutch chatter on engagement, I avoided buying the 1 piece lwfw because I didn't want to risk it. I can tell sometimes my stg 4 clutch shutters a little when I take off at low rpms, but the dmf does a good job of soaking it up. If it is as severe as you say, maybe your installer turned the test drive into a joy ride and was too hard on the clutch before breaking it in.. In either case just finish the break-in period and it should fade a little
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Three Rings Chandler's Avatar
    Jun 07 2014
    Recycle Bin
    South East
    I have driven the stage 3 and stage 4 EuroCode kit. If the shuttering is... shuttering on engagement, and your engagement is just a little rough, that is not going to change without some new technique. If it is chatter, then it is not going away. Breaking the clutch in more is not going to solve this issue regardless. The LWF is likely the culprit. I chained my clutch line a few days ago removing the vibration dampening valve. It did make engagements more controlled by a little.
    "People who think they know everything are a great annoyance to those of us who do."
    Aug 03 2014
    Queens
    I agree with Chandler, it's going to take some finesse to drive it now but you're still in the break in process so focus on getting through that.
    The breaking it in was rough, it shuddered so violently that I thought I made a mistake and turnt my car into a race car. After 300 miles it started to fade. Now I'm here, 1000 miles in. Engagement is still a bit harsh when warm and revs are low but no where near break in. So it does get better but you will also have to change your technique if you want to completely eliminate it.
    Previous
    Feb 25 2014
    Texas
    Makes sense, thanks a lot for the insight gents.
    I have attempted to engage at various RPMs and while shuttering is less pronounced when using higher revs, it is still there. Also, it makes me feel like I'm shredding the clutch when I engage at higher revs. This will take some getting used to I guess.
    10.65 @ 129mph
    Jun 20 2015
    NC
    My OEM clutch does this lol. Seems to be more noticeable in colder weather which makes no sense
    Apr 04 2012
    MSP
    Mine even does this sometimes and I have a stock clutch...
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by AudiS4B8 View Post
    Hey Guys,
    Thanks,
    Mickey
    I've been running the Eurocode Racing Clutch for half a year and I had the exact same issue.
    I did expect there would be some shudders since its not OEM and designed for hard shifting. It was really PITA for daily driving especially when you get stuck in the heavy traffic.
    Installation was performed by certified master Audi tech and I broke in the clutch properly and the shudders would never go away even after 1500 miles.
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    dont think it will go away, when i i was trying to decide what clutch to go with, this was a common thread that i kept reading about with the ec setup regarding 1st gear engagement.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by fitzydude View Post
    Not to hijack the thread but how do like the stg 4 clutch without upgraded flywheel? Any issues with resurfacing the stock flywheel? Does it launch well?
    Feb 25 2014
    Texas
    FWIW, I spoke to Dave from Eurocode at length on this issue. He said the majority reason for the shuddering is the LWFW. So for those that are scared of the shudder but want a stronger clutch, don't let the stage III scare you, just stick with OEM flywheel. He did say the shudder will never go away completely but will fade to some extent. But, like any car, once you become used to the application, you learn how to engage the car to minimize the shudder.
    I will continue to check back in with this thread as the I rack up more miles on the car. Still only about 275 city miles on the car since install. The recommendation is 500 city miles for when you can hammer the throttle again, but full break-in takes about 750-1000 miles.
    10.65 @ 129mph
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    My EuroCode stage 3 does the same thing. I have about 5k miles on it now. When it's cold, it's completely smooth, once it warms up which is usually over 20 minutes of "city" driving, it will shudder to varying degrees on from a stop engagement only. All gear changes are buttery smooth. I don't buy that the lightweight flywheel is the issue. I've had many light weight flywheels with aftermarket clutches over the years, and the friction material accounts for nearly all of the engagement feel. A stock dual mass may soak up a little shudder, but it won't get rid of it.
    You bought a clutch with a full kevlar segmented disc. It will never be smooth on engagement like an OEM organic disc will.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    12.83@107.3mph 1.85 60' (stock)
    12.24@112.62mph 1.74 60' (stage 2 - 93 octane)
    11.92@116.98mph 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jul 05 2014
    Houston
    Quote Originally Posted by Hofahome View Post
    The JHM stage 4 has been flawless, engagement and pedal feel similar to stock maybe slightly more aggressive. I purchased a new OEM flywheel to be safe, I couldn't find a shop that would resurface an OEM dmf.. It launches really well, in my mind you want a heavier flywheel with more momentum to get your heavy ass awd car moving off-the-line at the track as opposed to a lightweight fw.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Yeah, but that shifting 1st to 2nd though. Takes forever for the revs to drop enough for a great shift there.
    2021 Audi S4, P34 Intake
    Feb 25 2014
    Texas
    Quote Originally Posted by Vogz View Post
    My understanding is the stage III is not kevlar, the stage IV is kevlar.
    10.65 @ 129mph
    Jul 17 2010
    996 Turbo
    Batavia, IL
    The stage 3 is most definitely kevlar fiber. The stage 4 is a 6-puck ceramic.
    Feb 25 2014
    Texas
    Thanks for the info. Since you've had this clutch for a bit, have you learned to drive it to minimize shudder?
    10.65 @ 129mph
    Jul 17 2010
    996 Turbo
    Batavia, IL
    The best ways I've found to minimize shudder is quicker engagement or engaging just until it starts to shudder and then pushing the pedal back in and re-engage while the car is already rolling. It's not ideal, but if you want the holding power, heat resistance and life that the stage 3 will give you then you have to give something up.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    this. i presume that's the main benefit of the lwfw? Free'er quicker revs rising up and falling down? that 1st to 2nd shift is frustrating at times actually most all the time for me.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by Thurston View Post
    Yup, and 2nd to 3rd can be almost as bad. I an getting JHM LWFW installed, I'll have a full review in a few weeks, this will be my first ever LWFW on any car. This is the first car where I've felt like it was needed.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Guys, the revs "hanging" on some 1-2 shifts is NOT the flywheel. An aftermarket LWFW will NOT eliminate it. It's in the engine tuning. My car does it just the same as it did before my LWFW install.
    Jul 05 2014
    Houston
    I've always wondered what that is, could be excess boost that's built up when you immediately let off the throttle for a shift. Then the rpms hang to bleed it off?
    Jul 17 2010
    996 Turbo
    Batavia, IL
    It's probably something emissions related in the engine software.
    Apr 04 2012
    MSP
    +1
    It's designed that way... I was reading somewhere that it's supposedly to make for smoother shifts to let the rev hang. Also smooths out on/off throttle at higher RPM and just about eliminates engine braking....
    Apr 27 2015
    canada
    is it that delay valve in the slave line or w/e? so what does the lwfw benefit you in the s4 besides weight savings, sir? clutch feel and ease?
    Jul 17 2010
    996 Turbo
    Batavia, IL
    No, the delay valve has nothing to do with the revs hanging. The LWFW in theory removes rotational mass from the drivetrain freeing up HP to make the car faster in a straight line. Who knows if it really makes a measurable difference. The reason I bought a LWFW is because dual mass flywheels have a tendency to fail when abused and also because the friction surface can be replaced very easily. Thus, it will be the last flywheel I ever buy for the car.
    Feb 25 2014
    Texas
    Just wanted to give everyone an update on this:
    I have around 600-800 city miles on this new clutch and flywheel now and the car drives MUCH better. The shudder has gone down drastically. I believe this to be a combination of the clutch being fully broken in as well as learning to drive with the new setup.
    Unfortunately when I hit around the 500 mile break-in period, my car, like many others here, wouldn't start. The "depress clutch pedal to start car" label came on and my car wouldn't start for 20 minutes sometimes. I immediately thought it to be the clutch fork but after further reading the symptoms were more indicative of the master clutch cylinder needing replaced. Seeing as that was the much cheaper option as well, I opted to go that route. Problem completely gone, for now.
    Hope this helped scare fewer people away from these aftermarket clutches.
    On a lighter note, I launched my car for the first time ever. I was honestly scared that the clutch would slip like it did when stock but it gripped and ripped like crazy. I had to do it a few more times and couldn't wipe the grin from my face. AWD burnouts > RWD burnouts
    10.65 @ 129mph
    Aug 03 2014
    Queens
    Hmm .. I'll try changing out the master and see if that works.. Thanks for the tip !
    Yea this thing grabs
    Enjoy the clutch
    Previous
    Jun 07 2014
    Recycle Bin
    South East
    I see you are using the SMS tune - good to see. Are you liking the E85 tune?
    Where did you get your master cylinder at?
    Feb 25 2014
    Texas
    Quote Originally Posted by Chandler View Post
    Bought it directly from Audi, I get a discount at my dealer through a buddy.
    The car is FAST with the e85 tune. It needed a few tanks to run smoothly and spark plugs needed replaced (hit 40k miles). But I'm telling you, the difference from stage II 93 to stage II e85 is substantial. It pulls much harder.
    10.65 @ 129mph
    Jul 18 2011
    Westchester, NY
    I threw a stage 4 clutch on my car last year from eurocode, jeez was that a horrible idea lol. You have to rev the car up to almost 3k to take off and in between shifting fast the pedal sticks to the floor lol.Pretty sure the clutch is going now as well, I should have went with a stage 2.
    Current:
    2015 GTR FBO-600WHP
    2010 s4 prestige+: Every mod available
    Apr 27 2015
    canada
    I bet it does, the numbers they posted regarding the e85 stg II sure seemed substantial. Sleek ride s4b8.
    Apr 27 2015
    canada
    Quote Originally Posted by netimebut4 View Post
    That's awful man absolutely awful... what is the benefit of stage 4, just for monster power cars?
    Jul 18 2011
    Westchester, NY
    Tell me about it lol. Yes, I don't even know why its available. My intentions were to go stage 3 eventually or something to equivalent power. I got a good deal on a GTR and things changed lol. Now the car is basically stock with a very unforgiving clutch lol. eventually I will get the OEM clutch re-surfaced and sell the car as is.
    Current:
    2015 GTR FBO-600WHP
    Apr 27 2015
    canada
    Well speaking of monster power cars.. nice.
