Results 1 to 13 of 13
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    Spare and used parts (K04's, SRM shrouds, Dual mass flywheel, Etc.)
    I'm clearing out my garage for the winter and have a lot of part I found. Prices are without shipping but am willing to ship. I will also give discounts if you want multiple things. All prices are best offer, I guessed at some of the prices when I was not sure of them. Pictures are here.
    SRM shrouds (NEW)- $150
    K04's (unknown manufacturer, 12K, mimimal shaft play) - $500
    B5 S4 Dualmass flywheel - $120
    B5 S4 Rear Seats - $150
    B5 S4 Aliuminium trim (door pieces only) - $75
    B5 S4 Rear diff mount - $20
    B5 S4 oil feed line (Both sides) - $100
    B5 S4 oil return line (passenger side) - $25
    B5 S4 Pressure control lines (All)- $100
    B5 S4 ABS/ ESP control Unit - $50
    B5 S4 Xenon Lenses and projectors (no cut offs) - $25
    B5 S4 k03 housings - $125
    B5 S4 stock intercoolers - $40
    B5 S4 17" stock wheels (Pair with good tires) - $120
    B5 S4 rear o2 sensors with both sides of connector - $30
    B5 S4 thermostat - $10
    B5 S4 Centering spring - $20
    B5 A4 inner axle gasket (NEW) - $10
    B5 A4 Side trim piece (NEW) - $15
    B5 A4 rear brake pads(OEM one side) - $20
    B5 Hood hindges (NEW) - $25
    B5 Bumper bolts (NEW) - $10
    B5 Bumper clip (NEW) - $20
    B5 6 disc dc changer - $40
    B5 Slave boot and rod - $10
    B5 Headlight controller relay (#357) - $10
    B5 Blind spot mirrors (Diver side has a crack, passenger side perfect) - $100
    B5 Center console Black trim (shifter shroud ok, hazard missing 1 clip) - $30
    B5 2.5 bar map sensor - $25
    Boost gauge air filter (new) - $ 10
    Manual boost controller - $20
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    Aug 05 2013
    MA
    bump.
    Established Member Two Rings On3ok?'s Avatar
    May 10 2015
    Milford Delaware
    Where are you located?
    Sent from my SM-N915P using Tapatalk
    Aug 05 2013
    MA
    Mass, I commute from Harvard to Worcester
    Aug 05 2013
    MA
    Bump
    Aug 05 2013
    MA
    bump
    Aug 05 2013
    MA
    bump.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by Kenrevo View Post
    bump.
    pics of blind spot mirrors?
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Aug 05 2013
    MA
    Quote Originally Posted by King_ View Post
    Sorry for taking so long to respond here are the pictures:
    Drivers:
    Passangers:
    Panorama when they were in the car:
    Active Member Two Rings ZachB5's Avatar
    May 26 2012
    Longboard!
    Sacramento, CA
    17" wheels a set of four?
    2001.5 VW() Passat 1.8T
    Aug 05 2013
    MA
    Quote Originally Posted by ZachB5 View Post
    Sorry only a pair
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Veteran Member Three Rings ChescoS6's Avatar
    Jan 13 2007
    2012 Golf TDI 2003 Ducati ST4s ABS 2007 Ducati Monster S2R
    PA
    Do the wheels have center caps? What brand tires and are they all season or summer tires?
    Aug 05 2013
    MA
    Quote Originally Posted by ChescoS6 View Post
    They have center caps and the tires are all seasons. The tires have good tread and are wanli s1063. They were what came with the car
