Results 1 to 6 of 6
    Established Member Two Rings sly9's Avatar
    Sep 29 2015
    Columbus,OH
    Remove the headlight reflector
    Is there anyone have removed the yellow reflector of your headlights? Did you simply painted that part or replace to other material reflector? How and where can I find a store to do that? Thank you
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Buy Eurocodes.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jul 25 2011
    You can either send them in to a company like oss tuning or oneeighty and get them to remove it, or buy OEM euro spec headlights. I wouldn't diy it
    Jan 07 2011
    2013 C300 4Matic
    if you have a FL, its a lot easier to remove the amber reflector vs pre fl. with FL, you may be able to DIY if your comfortable enough. process is the same as the FL 4 headlights. as for pre fl, its almost indestructible.
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Three Rings Hatchman's Avatar
    Jan 14 2014
    B8 S5, G35, C-Max
    Huntersville, NC
    Buy ecodes. I bought ecodes and then sold my old, cracked stockers on ebay and was only out $300 after all was done. Well worth it IMO.
    And actually, I think Steve meant for pre FL, removing the reflector will almost certainly destroy the headlight. Mine cracked pretty easily while swapping the bulb out, watch out for the tip of the corner of the front fender.
    2010 S5
    Meteor Grey, Tuscan Brown, Tip, Prestige, Nav, B&O
    Borla Exhaust / AG M510 / H&R Springs / 034 Motorsports Motor,Transmission Mounts / Akebono / CR-15 / RS5 grill / E-Codes
    HEX-USB+CAN
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by Hatchman View Post
    isn't that what I said? lol
    but yes, if you have the funds, id def go for ecodes. not to mention resale value is pretty high on them. u lose very little in the end, and rock it for many years.
    Present:
    IG: bknewtype
