It's been a while, but I used to be a fairly active member here until life got in the way. My car is a 2007 2.0T Tip. Anyway, to the chase... I recently did my second timing belt (primarily due to a faulty water pump o-ring) and tested everything prior to putting her back together. She started up fine, so I proceeded to reassemble and did an oil change. I went to start her up and back her out of the garage and got nothing. Check the battery, it was ok. Scanned it and found an immobilizer fault: 01315 - No Communication to the TCU.
Where the hell is the TCU? What do I need to look for?
