Results 1 to 12 of 12
Thread: Salvage Value
    Senior Member Two Rings perm2008's Avatar
    Jan 18 2010
    Hartford, ct
    Salvage Value
    I recently crashed my imola b6 s4. The front passenger side was hit. Mechanic says the motor is shot. What did the insurance give you guys as a totaled value?
    Car details: Imola sedan 6 speed with silver alcantara with 126xxx.
    Would it be worth it to part out? Only aftermarket stuff is magnaflow exhaust and carbonio intake.
    B7 S4 Brilliant Red: Stasis Exhaust, JHM tune, H&R coilovers
    Totaled: B6 S4 Imola: 2.5" Magnaflow, Carbonio Hot air intake
    SOLD: Ebony Pearl B5 1.8tqm APR Stage II 93oct, ST coilovers, 3" Downpipe, K&N Conefilter, APR 3" TIP, 2.0 Red Coils with 034 adapters
    Totaled: Silvaro B5 front Trak Stock
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    good you are ok, can you post pictures?
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    yes, definitely glad you're doing OK. From your description, sounds like it was a T-Bone from the right side? Not your fault? The insurance should give you FMV. See if your attorney can get you even more! Don't take the 1st value they give you as they'll always low-ball the car's value.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by zcspec View Post
    +1
    Absolutely never take their first offer.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Jan 18 2010
    Hartford, ct
    I'm ok just pissed about my car. Thanks! Here is the damage. Oil pan was hit on the curb and drained out all of the oil. The mechanic JB welded the leak and put oil (really ghetto fix) and said it was knocking when he started it. He also said it felt like the engine looked like it was going to "jump out". I assume he meant it was rocking and I would like to think it's just the motor mount, as the cost of a new engine will total the value of the car.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Is the check engine light on? Get it vag comed so you can see whats wrong with the engine. Id buy it back from the insurance and fix itz
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jul 11 2014
    Chicago, IL
    Can you get a photo with the hood opened? I"m definitely betting it's totaled.
    Established Member Two Rings arrogntbastrd06's Avatar
    Oct 08 2015
    Nothing, it's empty now... haha
    Connecticut
    Quote Originally Posted by JDillon15 View Post
    I would be surprised if there isn't frame damage behind that fender and bumper. Audi designed these cars to absorb impact, and once they have they are usually salvage or totaled. If i'm not imagining things, the motor mounts and cross-member are supposed to fail and allow the engine and trans to drop down to the ground and slide under the driver in the case of a head-on collision so that huge V8 does not crush your legs and torso.
    Safety first!
    - Do unto others as you would have them do unto you -
    Stock 2006 Audi S4 25quattro Edition
    Jan 18 2010
    Hartford, ct
    The car is totaled!!! Next question now, Should I buy it back and part it out? It has magnaflow exhaust, carbonio hot air intake, silver alcantara rears are 9.5/10, fronts are 7/10.
    Oct 08 2015
    Connecticut
    Quote Originally Posted by perm2008 View Post
    Well I guess that depends on how much insurance will pay you for the car VS how much you think you can make by parting out.
    If insurance will pay out anywhere near what your part out value is, I'd recommend taking their money. Parting out can take a long time and you may not end up with the amount of money you would have had if you took your insurance money on the total.
    Jul 11 2014
    Chicago, IL
    Figure out what the buy back value is. Can you afford to sit on that money? It might take a while to make that money back. Depends if it's a DD or not.
    and think about what you can realistically get out of it. You'll probably want to price items slightly under market to move them quicker.
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    I have to admit this is freaking me out. The car just doesn't look that bad. OPs experience (really sorry for your misfortune) along with what arrogntbastrd06 is saying about the collapsible front end, means one solid hit and your car is gone. Throw in the insurance grenade to go with the timing component grenade.
