Results 1 to 4 of 4
Thread: Small oil leak
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    Small oil leak
    So it doesn't always seem to leak, I cannot pinpoint what will cause it... but its 20*f here today and I just went on a spirited ride and upon returning I noticed this.
    If you look at the oil pan, on the passenger side of the car, there is an oil line (a return perhaps?). It seems to be soaked and oil, and slowly dripping.
    I've also noticed that I can smell burning oil on the turbo/exhaust/manifolds from somewhere. Presumably the top of this line in question?
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Nov 19 2015
    Buffalo, NY
    Nobody knows what the part I'm referring to is, and why it might be leaking and how to fix it?
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Pretty sure you are describing the oil return line from the turbo. If the line itself is wet, the leak is from the turbo side of things, possibly just the gasket that connects the return to the turbo. If it is just leaking on the oil pan around the oil return line then its most likely that gasket or o-ring that needs replacement.
    If the top of the line is leaking it could be running onto the CAT or the turbo could get hot enough to smoke, also take a look at your valve cover gasket.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Nov 19 2015
    Buffalo, NY
    Ohh if that is indeed an oil return line, I could definitely see that dripping onto the exhaust, causing my burning oil smell. I think the leak is at the top of that line, it drips down, and leaves a very tiny puddle on the driveway.
