Results 1 to 40 of 42
    Senior Member Two Rings street sleeper's Avatar
    Jan 04 2015
    Pittsburgh, PA
    Would you buy Blizzaks again?
    Coming up on my 1yr anniversary with the S5. Drove through last winter on my summer/performance tires. I know, I know. Not smart and lucky nothing bad happened. With that said, this year I decided it was time for some appropriate shoes.
    Ordered a set of Bridgestone Blizzak LM-32 winter/snow tires from TireRack for about $1200 to run on my stock wheels.
    Never owned a set of true winter/snow tires, but decided to go with Blizzaks because it seemed to be the popular choice here on the forums. So just wondering if you have Blizzacks, would you buy them again?
    Pros? Cons? Any better winter/snow tire out there?
    PS (I hear Blizzack technology was designed after studying polar bear paws. That pretty badass, even if it's just a marketing gimmick.)
    2008 Audi S5 (6MT)
    Meteor Gray / Magma Red Leather / Carbon Inlays
    Euro Spec Headlights / 35% Tint / Satin Black Grille, Fogs, & Rear Valence
    AWE Track Exhaust / AWE Carbon Intake / Short Shifter / H&R Sway Bars
    H&R OE Springs / Brembo Brakes / BBS CH-R 20x10.5 / Michelin Pilot Super Sport XL 275/30ZR-20
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    I assume you have summer wheels and stock wheels? If not, I would get a cheaper set of wheels. Saves the mounting and rebalancing fees. As well as helps to protect those nicer summer wheels.
    As for the tires, I haven't personally used them, but all the people I've seen talk about them say they're really good.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    No brainer, Blizzak's are one of the best winter tires you can buy, bar none! They are excellent in snow and provide a firm level of driving confidence. You won't go wrong!
    Veteran Member Four Rings ryanhmusic's Avatar
    Aug 05 2014
    jack stands, a power washer, hand tools, bones of my fallen enemies, etc
    Quote Originally Posted by zcspec View Post
    Nokkian's are better in my experience.
    But Blizzaks are damn good.
    I'm living for the day I can park something Italian inside of my house.
    I had one wild summer on match.com. -some jackass
    01100010 01100001 01101110 01100001 01101110 01100001 00001010
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    I ran Blizzak's on my C7 A6 and loved them. There was a huge difference between the stock tires and the Blizzaks and I would absolutely buy them again.
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by JDillon15 View Post
    Right now, I just have the stock wheels with summer/performace tires on them. That's what came on the car.
    Ideally I'd like to make my stock wheels my 3 month winter wheels and buy a set of BBS wheels for the other 9 months. But those BBS wheels are pricey!
    So I was just going to swamp tires on my stock wheels. Probably not the best, huh? Going to be pricey to mount and balance and then mount and balance again in 3 months.
    Maybe I should look into buy a cheap pair of winter only wheels.
    2008 Audi S5 (6MT)
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    You only have to do 3 months on a winter setup? Lucky...
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by street sleeper View Post
    I'd look into the cost of mounting and balancing. If you buy new tires or wheels, they'll likely mount or balance for free the first time. If you have bbs, you will definitely want a winter wheel. Maybe use your stockers as winters and plan on buying bbs in 3 months? Not sure of your financials.
    Jan 04 2015
    Pittsburgh, PA
    After buying a $1200 set of winter tires, it's a bit tighter.
    2008 Audi S5 (6MT)
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by HazeMyth View Post
    I may only only have 3 months of winter, but you have killer snowboarding for months on end. Jealous!
    2008 Audi S5 (6MT)
    Jul 11 2014
    Chicago, IL
    Yeah, I guess it just depends what makes sense for you. I personally run all seasons as my winters are fairly mild. Plus, I'm in a b7. Can't really justify ~6k wrapped up in wheels and tires for a ~10k car.
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Yes. We have had at least half a dozen sets over the years. And we continue to buy more, when needed.
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Have run Blizzaks as my winter set up for last ten years and consider to be one of the best snow tires around. That said, I have heard they aren't as good after a few seasons as they begin to lose tread, but have not had that problem as I replace before that happens. Also worth noting is the LM 32 is a "high performance" snow which means it will be better than most snows on dry roads yet not as aggressive in snow and ice as the WS Blizzak which I believe only comes in 18 inch anyhow. Agree that swapping tires every year to same rims is not ideal. Keeping stockers as is and buying 18 beater rims with cheaper WS Blizzaks could be an option. I chose the Nokian R2 this year for snows as I wanted to use the stock 19 rims and preferred a more aggressive snow than LM. However, I haven't tried them in the snow yet so can't really compare to Blizzaks performance. Also, was told by mechanic that the Nokians were some of the worst tires to road force balance he has ever seen, with one tire not coming anywhere close to Audi specs. I have read nothing but great reviews for the LM and think you will really be pleased with them.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Jan 04 2015
    Pittsburgh, PA
    Here's a question...
    Do cheap steel wheels even exist for Audi? 19x8.5
    I've been looking online and haven't come up with anything!
    2008 Audi S5 (6MT)
    Veteran Member Four Rings B8 S FOR's Avatar
    Feb 15 2011
    Pittsburgh, PA
    I run the Dunlop Winter Sport 3Ds...good to go..no issues. The Blizzak are too noisy and tread wear is terrible.
    AUDI 4 LIFE.........B9 S5 Cab Prestige/ Mythos Blk Met
    Gone but not forgotten:
    2015 B8.5 S5 Cab
    2011 B8 S4
    Veteran Member Three Rings Johnhanson's Avatar
    Oct 26 2013
    Regina
    Quote Originally Posted by B8 S FOR View Post
    I had one set of blizzaks on my old G35 - they were great plowing in a straight line and especially in loose snow and slush, but they were very poor performing on cold dry pavement.
    I switched to old Dunlop M3s which were still I would say 90% as good in slop and slow but amazing on cold dry pavement. They actually almost felt like a summer performance tire for winter. Far less sidewall flex and what seems like a firmer compound.
    I now am on my third winter with Dunlop 3Ds and perform basically the same, but are incredible combined with the Quattro. Minimal wear, great comfort and the best aggressive winter driving performance. I expect to get at least four winters out of these.
    Basically if you want a safe comfortable dependable tire to get you around driving like a gramma - get blizzaks. If you want something that is still very good but lets you have a four season performance car - get the dunlops. Amazing performance winter tire.
    2013 Audi RS5 Coupe | Phantom Black | Everything except ceramics | Capristo | Eventuri | 15/10 H&R | Rotors when it's cold | V-Spokes when it's warm
    2015 BMW X5 35d Msport | it runs on kerosene | notsport | baby seat
    dead and gone.....
    2012 BMW X6 50i | it had a bike rack
    2010 Ram 1500 | hhhhemi
    2008 Mazda RX-8 | it go-karts
    2006 Infiniti G35 coupe | my lady
    1998 Eagle Talon esi | no turbo powers
    Aug 28 2015
    Illinois
    After experiencing pothole-induced rim destruction, I went with inexpensive Rial M10 18x8.5 wheels and Michelin X-ice Xi3 tires for their 6 Years / 40,000 miles treadlife warranty. I don't need high-performance winter tires and got tired of buying winter tires every 2 years.
    Prism Silver RS5
    Veteran Member Three Rings mjr034's Avatar
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    I picked up a winter set off the forums here last year with blizzaks. For our cars - you'll be fine running an 18 in wheel - brakes clear with no issue.
    Much cheaper than 19s when buying tires. I'm running an old OEM S4 winter setup (18x8 twisted spokes) - Looks nice for winters and the blizzaks are fantastic performing in our snow conditions around Pittsburgh.
    My advice (also what I did), invest in a solid winter set now. Wait until summer next year to pick up some BBS or whatever else tickles your fancy then.
    2013 S5 3.0 TFSI ~ Prestige | DSG | Brilliant Black | Carbon Atlas
    | 034 | APR | AWE | BBS | BFI | BILSTEIN | ECS | VORSTEINER |
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by mjr034 View Post
    I did something a little dumb. I ordered my tires already, arrive today, to fit my stock wheels. Which is fine since my original plan was just to run them on stock wheels.
    Of course I didn't really think about what a pain it will be to have the winter tires pulled back off in April and have summer tires put back on those same stock wheels. So I thought some cheap steel wheels for winter would solve that problem! Of course steelies in that size are impossible to find! Maybe I'm start another thread seeing if anyone has found steelies or has a set they're willing to sell.
    2008 Audi S5 (6MT)
    May 29 2012
    Evergreen, CO
    Quote Originally Posted by Powderhound View Post
    This is the most important comment in the whole thread, and something that seems to have eluded a number of posters. While the LM 32 is a "Blizzak" tire, it is night and day different than the "true' Blizzaks like the WS 60, WS 70 and WS 80, both in terms of tread compound and tread design. The WS series will run circles around an LM 32 (which is what I run on an RS4 during the winter) in the snow but in all other conditions the LM 32 is a superior performer, including in terms of sidewall stiffness, lack of mushiness, and tread life. Plus, the nanocell or whatever it is compound in the WS series wears pretty quickly, and you end up with an all-season tire without knowing it until too late.
    I can also report that my S4 on Wintersport 3Ds is much more surefooted in snow conditions (and we get those a lot in the Colorado mountains) than the RS4 on LM32s.
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    For my S4 I ran Michelin PSS in the summer and Vredstein Wintracs in the winter. First 2 winters I ran Dunlop Wintersport 3d. All of them made the S4 into a tank. Now with the AMG I am throwing Blizzaks on cause it needs a dedicated snow. Quattro can do high performance winter tires. I mean I went up incredible hills in 10 inches of snow in the s4 with the dunlops and vredesteins and they are not dedicated snows.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Established Member Two Rings Mlaudisa's Avatar
    Jun 06 2015
    Toronto, Canada
    I put on 275- 35 Blizzaks LM-32 in the last 4-5 weeks, mounted on 19" VMR rims. It has been unseasonably warm here this fall and winter so far, so I cannot comment on their performance in snow and sleet, but I found a huge difference on how the car handles Vs the factory 275-30 20" P-Zeros. For starters, the steering wheel offers much less resistance, even standing still and even in Dynamic setting. At speed, the car is not as precise and planted as on summers, and when taking corners at speed it looses grip controllably and gradyually but at lower speeds. I noticed these differences most starkly right after the switch, and I would describe these tires as softer and a musher than the Pirellis. I'm sure they'll be excellent in snow and ice however, but I wasn't prepared for that big a change in handling characteristics.
    Mar 08 2013
    2013 RS5 Cab / 2015 Q7
    Southern Illinois
    Quote Originally Posted by PedroRS5 View Post
    Please PM me as I have some ? about what tires you had. Don't want to hijack the thread. Thanks
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    If you want to keep handling... STRONGLY suggest PA4s. They feel almost as good as my summers.
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    +1
    I'm running LM 32 in 255/35/19 and I wasn't impressed with the snow performance... felt all season-ish... my tire guy tells me it has more to do with the size than anything else... I suspect the Dunlop 3d or any ws blizzak would be better if you want great snow performance... along with a downsize to 18's.
    I was so displeased with the LM 32 in the snow that I'm in no rush to swap out my dws on 20's this year just to see how much they differ in snow performance... the LM 32 for me didn't feel surefooted at all in snow conditions... very disappointed.
    my 2 cents
    Quote Originally Posted by DOCEVG View Post
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    For the money, Blizzaks are the best you can buy. The wife's V6 FSI Touareg rides on that in winter and Toyo A/T in summer. My V8 FSI Touareg rides on Hakka 5s in winter and Toyo A/T in summer.
    If money is no object, Hakka 8 studded from Nokian is the definitive tire which is what I have on the RS5 (285R30x20). But then I live a couple of miles from the arctic circle...
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Senior Member Three Rings jrabakker's Avatar
    Feb 27 2014
    You could also call it a little smart: now you'll gave to go out and get some awesome new summer wheels!
    2014 S5 | Premium Plus | Estoril Blue | Black Napa Interior | Sports Diff | Adaptive Damping | Side Assist | Supercharged badges | HR OE springs | 10/15 mm spacers fwd/aft | APR stage 2 | AG M510 - 20x10 - 275/30/20 |
    1st Car | 1988 80 B4 | Blue
    2nd Car | 1998 A3 1.8T | Sport Green
    Veteran Member Three Rings FamousLastWords's Avatar
    Feb 06 2013
    I've been running Blizzaks on my stock 18's for two seasons now, dealing with up to a foot of snow and slush various times. I can't speak highly enough about them, but especially about how the car stops; truly makes me excited to drive in the snow each winter.
    (I do appreciate the irony of my last sentence and my username, btw. )
    2015 S5 | 034 Stage 1
    Active Member Four Rings DinB's Avatar
    Apr 20 2012
    O
    They are ok in straight line, but I experience slippage even when making gentle turns.
    Oct 18 2006
    Audiville
    +1
    again, maybe it's the size I'm running, lm32 on 255/35/19... what are size are you running DinB and are they LM32?
    Quote Originally Posted by DinB View Post
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    I have been running 245/40/18 LM60 for the past 2 season and I have no complaint at all! This year I got a set of 255/35/19 LM32 because of the RS brake I put on so now you made me worrying...
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
    Mar 18 2015
    2015 GL450
    IL
    Just drove mine for the first time in snow (put them on Sunday) and very happy. Used to use 3D's and I didn't notice any performance loss. Maybe it is the size I'm running...255/35/19.
    Wasn't much snow so I can't comment on heavy snow traction yet but so far so good.
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Nov 04 2010
    I mounted my blizzaks on the AMG yesterday. It has been raining here. They absolutely are terrible in the rain. I guess next time Ill do Wintersports or Wintracs.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Oct 26 2013
    Regina
    Quote Originally Posted by ENVē View Post
    Rain is a non issue for the Dunlops. Probably all-season type performance in rain.
    dead and gone.....
    Nov 04 2010
    Quote Originally Posted by Johnhanson View Post
    Yea that I know, I had Dunlops on the s4 for a couple of seasons and vredesteins for the others
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Oct 26 2013
    Regina
    I imagine an AMG would be suboptimal in the rain regardless of tire as well
    dead and gone.....
    Feb 08 2013
    I have LM32 on for ~ 3 weeks, never face heavy snow but it did ran through heavy rain and feel the same as my summer PSS
    May 21 2010
    Thats what I was thinking. Need Hakkas probably but NOT a performance winter tire for sure IMO
    Nov 03 2015
    London Ontario Canada
    have had blizzaks in past and currently on RS5 have 245/40-19 LM-32 They are very good in snow. definitely softer feel than the P-zeros obviously. Last car S4 had Michelin PA4's which were maybe a little firmer feeling, also good in snow but I would give the edge to the Blizzaks for really bad weather
    Feb 27 2014
    I have a set of zottozero's and from what i can tell they do great. Nice grip in snow (but havent seen too much yet) and good handling in rain. Very suitable for the PNW.
