Results 1 to 10 of 10
    Apr 30 2007
    Audi RS brakes and GMG sway bars
    Audi RS5/R8 etc brake setup (SOLD):
    direct bolt on (front) on the b8/b8.5.
    2x 8-piston calipers(front)
    2x ECS tuning full floating wavy rotors (front)
    EBS red stuff pads for front and rear
    2x OEM RS5 semi float wavy rotors (rear)
    2x OEM single piston rear calipers (it's the same, no difference)
    note: the rear rotors are not direct bolt on, you either need to use a 5mm spacer between the hub and the disk, or install the rs5 hubs. I decided to use the spacers after getting most of the necessary hardware to install the hubs (decided it was too much hassle). Both spacers and hubs+hardware(bolts) are included
    The setup was a big improvement over stock, both in pedal feel and stopping power. It was used for about 10k miles/1yr, but is in really good condition since I don't drive the car that hard
    GMG front and rear adjustable swaybars ($350 OBO):
    Really helped with the steering feel and handling. (install the front on least stiff, rear on stiffest). Has about 1yr of use as well.
    I'm located in Southern California (inland empire and LA area). Pickup is preferred but will ship at buyer's expense.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    What size mm are the rotors? Can you PM me some pics plz
    Apr 30 2007
    Quote Originally Posted by Pyromatic177 View Post
    The fronts are these rotors: https://www.ecstuning.com/ES2785596/
    The rears are these rotors: https://www.ecstuning.com/Audi-B8_RS...ors/ES2642807/
    Here are some photos (car is a little dirty, the parts will be coming off this week): http://imgur.com/a/h11Xc
    Aug 02 2015
    Corning NY
    The imgur link didn't work. But i am interested! Shoot me a pm and I'll send you my info for pics
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Do the sway bars come with links ?
    Apr 30 2007
    Quote Originally Posted by s4matty View Post
    no links
    Aug 15 2015
    2 feet
    Niagara canada
    Would you be willing to sell just rear sway
    Active Member Two Rings robertm's Avatar
    Oct 01 2011
    corona ca
    I'm interested in the brakes if you still have them
    Apr 30 2007
    Brakes are sold
    Nov 28 2015
    Montreal, QC
    pm'ed about the Sway bar, but never got a reply. If you want to sell them. hit me up and they are gone.
