Not sure if the answer to this is floating around anywhere, but I've searched and looked at the wiki and cant find anything.
I know most people that do the swap retain the tip engine harness, however I removed mine and swapped in a 6 speed harness from the donor vehicle.
On the swap wiki step 3 it states the following:
Reverse Light, 2 wire connector on Transmission Right Side
1. Buy/make a harness using 2-pin connector
2. Run the harness up to grommet in the firewall next to O2 sensor brackets, and through the firewall to the ECU Box grommet
3. Left A-Pillar Brown connector Pin 8 Blue/Red wire, cut-off old lead and splice-in new wire to Reverse Sensor
As a side note, does the pics on the 6 speed wiki load for anyone (http://s4wiki.com/wiki/Tip_To_6spd_Conversion)? I can't seem to view them at all :(
TIA <3
