Results 1 to 11 of 11
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    Window washer light wont go away
    The light pops up on my dash. I've put lots of window washer fluid in (granted, it's not full... but probably half way or more) and the sensor wont leave my dashboard. I'm thinking teh coolant sensor is dirty?
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    time to start searching a bit more man, you'll find alot of people have answered common questions years before!
    heres a link link to other thread post
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Nov 19 2015
    Buffalo, NY
    Ok so I looked into the reservoir, and its DEEP. I think I didn't have it full enough to trip the very very top sensors. So I think that was my fault for not topping off the fluid.
    Second. It seems like my washer fluid is leaking like a bitch. Ugggg. It wasn't leaking the past week or two, and today since I used it, it's leaking like a bastard.
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    Quote Originally Posted by volkswagensRus View Post
    The reservoir leaking is also very common on these cars, especially as they get older. The window washer pump is held in place by a grommet. Once the grommet hardens, it leaks. Usually a cheap fix but like most things a bit of a pain to get to.
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Nov 19 2015
    Buffalo, NY
    Damn. It's probably now leaking from being in the 20s and 30s that the grommet shriveled up and is now leaking. I guess I can find a DIY on that somewhere?
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    I fixed mine this fall. I scraped up my knuckles pretty bad pulling that sensor out. In order for to gain access I had to move the power steering reservoir and miscellaneous electrical bracket to access it. The symptom I had was every time I would fill it up to capacity the car would randomly alarm for fluid low. I wouldn't recommend doing this job in the cold, plastic connectors do not like it.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Nov 19 2015
    Buffalo, NY
    Fair enough. Replacing the sensor fixed the leak?
    Sep 13 2012
    Adelaide, AU
    Easier to access washer bottle through driver fender, remove wheel, remove fender liner, access bottle
    Sent from my E6653 using Tapatalk
    Nov 19 2015
    Buffalo, NY
    ^Nice!! Good insider tip. Thank you.
    Apr 26 2010
    North Jersey
    The sensor is stuffed into a grommet. Buy a new grommet and sensor to eliminate any future problems.
    Quote Originally Posted by down_n_dapper View Post
    I wish I would of did this! Would of saved me time and skin.
    Nov 19 2015
    Buffalo, NY
    Perfect, will do. I'll update this thread when the car is fixed.
