Hello everyone,
In the morning after 2 minutes of driving the "Fault in the brake system" and the "ABS" warning signs both showed up and stayed on the dashboard. However the brakes were working fine. I drove about 500 meters and pulled down but not stopping the engine for a minute. Both lights were still showing up. I've then restarted the engine and neither of them came up again while coming to work (it took about 30 minutes). After arriving to work I've checked the brake fluid level and it's fine so I guess no leakage. The brakes still work perfectly and not experiencing anything bad with it.
Two more information: recently it's a bit colder outside (I'm parking in a garage) and the lights showed up when I was accelerating from a break.
Any idea why this happened?
Thanks a lot,
Daniel
