Hey guys, I have a 1999 audi a4 avant 1.8t (AEB engine code) and just got done doing the timing belt service. It appeared that the new exhaust cam seal had a little bit of oil getting past the seal where it meets with the camshaft (inside of the seal). Installed another cam seal thinking a lip was rolled when installed but it still looks like there is a steady layer of oil there still and you can see it slowly seeping out where the cam meets the seal with the engine running. The new seals were oem "new design", installed dry, and the cam itself didn't seem to have any wear on it. Could it be that pressure is pushing oil past the seal? What's a good way to test if that's the issue? Any help would be appreciated!
Just fyi the PCV on the inlet pipe was recently replaced but I believe there's another valve by the intake manifold?
Thanks
